Old 06-22-2015, 10:17 AM   #1
Krewmaui
Krewmaui's Avatar
Drives: 2014 Scion FRS Firestorm
Bore size help
Okay guys I need some help. As we all know the twins have a 5x100 lug pattern. I'm buying konig torch wheels that have a 5x114.3 lug pattern thus I'm also buying 25mm spacers/lug pattern adapters that will change my lug pattern to the 5x114.3. The spacers have a bore size of 67.1mm and the wheels have a bore size of 73mm and the cars bore size is 56.1. So my question is, do I get 56.1mm to 73mm hubcententric rings or 67.1mm to 73mm rings?
Wheels
18x10 +35 rear
18x9 +35 front
Krewmaui is offline   Reply With Quote
Old 06-22-2015, 11:07 AM   #2
gramicci101
Off Topic
Hub-centric rings aren't really necessary, because our wheels are lug-centric, not hub-centric.
You're running an 18x9 +35 wheel, plus a 25mm conversion spacer? So basically the wheel is 18x9 +10. That's going to stick out. A lot. Do you have a widebody kit on your car?
For reference, here's an 18x9 +21. Yours will stick out another cm.
http://www.ft86club.com/forums/showthread.php?t=38410
Old 06-22-2015, 12:02 PM   #3
Krewmaui
Krewmaui's Avatar
Yea I'm going rocketbunny
Series.Blue hub bore size lugao Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-02-2015 10:51 AM
Center Bore MooKz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 03-09-2015 03:56 PM
Exhaust bore Tilly Forced Induction 3 09-23-2014 02:21 PM
Hub Bore Correction Wesley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-02-2013 08:00 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
