Old 06-03-2019, 10:32 AM   #1
entaroadum
Drives: 2013 Subaru BRZ
Main journal size mark on block
Hello,
I've been trying to make sense of what this means in the service manual, but haven't found a definite answer:
Can someone help me understand?
Thanks!!
entaroadum is offline   Reply With Quote
Old 06-03-2019, 11:17 AM   #2
Silvermk2
Drives: Toyota Supra 2JZGTE VVTi
If its how Toyota does it there is a also numbers stamped on the crank. You add the number on the crank to the one stamped on the block and you get the bearing shell size used when the engine was built. I think there are about a half dozen different sizes. The rod bearing have one stamped on the rod end and the other on the crank.
Silvermk2 is offline   Reply With Quote
Old 06-03-2019, 12:06 PM   #3
maslin
Benz Tech
Drives: 2017 BRZ Premium
Mercedes is the same way. Block is stamped across all bearings, crank is stamped at the end. There's a chart that gives you the correct main bearing sizes.
maslin is offline   Reply With Quote
Old 06-03-2019, 12:31 PM   #4
fika84
fika84's Avatar
All the markings on the 2 blocks I have are 2's for the main bearing sizes.. Anyway, I've found a few threads that help explain a bit more. When I ordered bearings this didn't come into play, and as long as you're measuring the bore, the bearing thickness and the crank diameter and/or using plastiguage, you should be OK if you put them within spec.
https://forums.nasioc.com/forums/sho....php?t=2052088
https://www.ft86club.com/forums/show...?t=5778&page=2
According to Jeff, the largest difference (between 0 & 5) is 0.0005".
fika84 is offline   Reply With Quote
Old 07-24-2021, 01:13 AM   #5
Trdfrssx
Trdfrssx's Avatar
Drives: 2013 Scion FRS
From my research the "Main Journal Size" stamp on the block is for manufacturing purposes only and is not a determining factor for selecting engine bearings sizes. The marking is a Subaru trait and used on older Subaru engines as well, there is some info on this on the NASIOC forum.
Trdfrssx is offline   Reply With Quote
Header to Block bolt size? jnmxcvi Engine, Exhaust, Transmission 7 09-23-2019 10:58 PM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 01:26 AM
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 05:21 PM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
WTB Main Body ECU Acree Interior Parts (Incl. Lighting) 2 03-05-2013 05:31 PM
