Old 03-24-2020, 08:22 AM   #15
sexyslidez33
Drives: 2013 Scion FRS, 2003 Nissan 350Z
Originally Posted by mrhayes1 View Post
I hate being that guy that asks questions that are no longer relevant, but why did you buy that car? I hope you got a good deal knowing it was wrecked or something. If you bought it from a dealer (which I highly doubt) I would highly recommend you try to take it back per lemon law regulations.
Anyway, my advice is take to a reputable shop for a thorough inspection and alignment. If a car was badly wrecked, the alignment shop will likely have difficulty doing the alignment and should know something is up and will give you an idea of what is damaged. If a car was in a fairly serious accident, every suspension component could be at least somewhat bent or damaged. I would befriend the alignment guy/shop and see if you can take a peek under the car when they do the alignment/put on lift. It is much easier to look at the bottom of a car and see what's what when it is 5 feet off the ground. Good luck.
And for the record, not sure why people are even suggesting using string and a tape measure for checking alignment. I mean, I don't necessarily doubt that it can be accurately done but you would certainly need to know what you are doing for that process.
Well the car was $6000 for a 50,000 mileage car. Straight body and frame, other than the bent suspension components. Shouldn’t be a huge problem to fix I was just a bit shocked that when I replaced the rear lower control arm that I didn’t know it would affect the steering wheel orientation as it corrected prior to the installation.
On a slight update, I adjusted the camber on the rear arms to the middle setting and the car tracks much better and is actually drive able to the alignment shop.
sexyslidez33 is offline   Reply With Quote
The Following User Says Thank You to sexyslidez33 For This Useful Post:
p1l0t (03-24-2020)
Old 03-24-2020, 09:58 AM   #16
Tokay444
You don't need a laser rack to get a dead perfect alignment.
A laser rack is so any oil change monkey to align a car while the pan is draining.
The Following User Says Thank You to Tokay444 For This Useful Post:
p1l0t (03-24-2020)
Old 03-24-2020, 10:21 AM   #17
cjd
cjd's Avatar
Drives: 2017 BRZ
For starters, you need an actual level surface...
I'm glad I do my own right now, but the car has been in process for over a week. Think the dust from the car made me feel like crap. Not that I'll be driving any time soon anyway... It always takes me hours to corner balance and align. I don't recommend it.
C
Old 03-24-2020, 03:47 PM   #18
mrhayes1
Drives: 2013 Scion FRS white
I would wear my wife panties and do dishes before spending hours in the garage trying to do an alignment with string and a tape measure. Sounds like a job that requires a lot of crystal meth.
mrhayes1 is offline   Reply With Quote
Old 03-24-2020, 04:39 PM   #19
Tokay444
It's really REALLY not that bad.
Old 03-24-2020, 09:35 PM   #20
Grady
Grady's Avatar
C
Flat is more important than level.
The Following User Says Thank You to Grady For This Useful Post:
Tokay444 (03-25-2020)
Old 03-24-2020, 11:31 PM   #21
cjd
cjd's Avatar
Drives: 2017 BRZ
Ha. I read the first bit of my comment and thought the same thing. Absolutely right.
*Help* weird problem with my head unit. Mikereedom Electronics | Audio | NAV | Infotainment 4 01-29-2019 08:00 PM
Weird problem.. Pls Help. PresiO. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 12-01-2017 01:03 PM
Really weird problem: Have to fill with fuel very slowly Kido1986 Issues | Warranty | Recalls / TSB 31 08-20-2017 11:11 AM
Weird electrical problem itsAlex Scion FR-S / Toyota 86 GT86 General Forum 24 08-17-2016 07:56 PM
weird problem during traffic jam yesterday Minovsky Engine, Exhaust, Transmission 39 05-14-2014 01:46 AM
