Old 05-09-2014, 09:57 PM   #1
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
weird problem during traffic jam yesterday
So i was just stuck in traffic and for around 20ish minutes the car kept jerking back n fourth at 1st gear im in an AT frs. It would drop from 1k rev down to 500 and then back up while rolling.. Then the A/C started warming up and then it turned completely warm air for a good 5 mins... even while stopped it randomly went from 1k rev down to 5 etc etc.. not sure what happened is it just my car or is it normal?
I believe i have posted in the wrong topic how can i move this to the issues category?
Minovsky is offline   Reply With Quote
Old 05-09-2014, 09:59 PM   #2
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Check the AT fluid level???
Subaru STI :
The Following User Says Thank You to Kimsey47 For This Useful Post:
Minovsky (05-09-2014)
Old 05-09-2014, 10:04 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
I'll bet that you began to overheat and the system shut off your AC compressor.
You arent really supposed to use the AC unless you are moving.
The Following User Says Thank You to stugray For This Useful Post:
Old 05-09-2014, 10:13 PM   #4
Minovsky
Minovsky's Avatar
oh shoot really? =[ my 86 what have i done to u!!!!! i really didnt know
Old 05-09-2014, 10:16 PM   #5
gramicci101
Off Topic
For seriously? That's about the dumbest thing I've ever heard, but I could genuinely see Subaru saying it with a straight face.
The Following 4 Users Say Thank You to gramicci101 For This Useful Post:
Craig (05-10-2014), evan (05-10-2014), kodyo (05-11-2014), Sportsguy83 (05-11-2014)
Old 05-09-2014, 11:14 PM   #6
radroach
Drives: car
On the manual if you bog the engine it will definitely jerk back and forth, which is typical of subaru engines. The AT version should keep itself from bogging in this way.
Old 05-09-2014, 11:17 PM   #7
J_kennington
Drives: 2013 asphalt scion FRS
eh, are you sure you weren't barely hitting the pedal? at really slow speeds mine will "jerk".
as for the "ac not meant to be used unless moving"...ill...just leave that alone.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 05-09-2014, 11:52 PM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
The jerking is the torque converter locking up. If you shift into 2nd before coming to a complete stop, it won't jerk.
The AC thing is "normal" in these cars. It's the AC compressor cycling.
I have these issues too ...but if you do a search it's somewhat normal.
N1rve
Old 05-10-2014, 12:00 AM   #9
Fortis
Fortis's Avatar
Drives: 2014 FR-S AT Asphalt
I'd have to agree with the AC theory. Last week it was 90+ and I got to work a bit early so I was sitting in my car waiting to start. I had my AC on and my idle was very erratic. I turned off the AC and the idle went back to normal. I turned the AC back on again to see if the idle would go nuts and low and behold it did it again. I got out of my car and popped the hood to take a look. A few seconds after I popped the hood the the high fans turned off and idle went back to normal (with the AC on). I guess it just gets really hot under their. As soon as I shut the hood, the high fans turned on again and the idle went erratic. Heat and the high fans definitely seem to be a contributing factor.
Fortis is offline   Reply With Quote
Old 05-10-2014, 12:41 AM   #10
Pandle
Drives: CBS BRZ
I also have an auto and if I'm in first and the car gets up to 9 mph or a little higher and I let off the gas, the car will start jerking until it goes to second. I never noticed anything with the ac though.
All kinds of gains....
Pandle is offline   Reply With Quote
The Following User Says Thank You to Pandle For This Useful Post:
Minovsky (05-10-2014)
Old 05-10-2014, 12:47 AM   #11
stugray
I'll try to explain slowly....
Air Conditioners are heat pumps. They pump heat out of your interior into (wait for it) into your radiator (the thing trying to cool your engine).
AC systems take quite a bit of power: both HP from the engine and extra electricity for the fans (more drag on the alternator).
So while sitting in bumper to bumper traffic you are running a car in a way that generates the most heat while providing it the minimum cooling capability.
The system can detect the rising temps in the cooling system, first the car will turn on the electric fans to try to provide extra cooling for the radiator.
It even has more than one speed for those fans.
If that is not enough, it will take further measures and turn off your AC compressor. Why? because it knows that it generates more heat.
So I will rephrase "People who know what is good for their cars will not sit in traffic, not moving, with their air conditioner running"
Old 05-10-2014, 01:17 AM   #12
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
This week I took 2 cat naps in my car with outside temps in high 80's to low 90's. My car sat for about 30 minutes this way each time at work. If you leave the AC on 1 (for FRS), the idle will be erratic with fans cutting on and off. Leave the AC on 2 and it will be smooth and consistent with fans always on. No rough idle issues. When it was time to get up and pull into the main parking lot the car drove fine. I am in an manual however. Cannot say much for auto.
JimmyMac is offline   Reply With Quote
Old 05-10-2014, 01:19 AM   #13
gramicci101
Off Topic
I know how it works, I just think it's stupid for the manufacturers to decide it's ok to turn off the AC if the car isn't moving. I'd rather have paid a few more dollars for a larger radiator than be stuck in a traffic jam on a hot day and have my AC shut itself off.
Old 05-10-2014, 01:49 AM   #14
Minovsky
Minovsky's Avatar
its really interesting good thing it's not something wrong with my car.. i was pretty scared for a while @-@
Really weird problem: Have to fill with fuel very slowly Kido1986 Issues | Warranty | Recalls / TSB 31 08-20-2017 11:11 AM
Won't go into first when hot and in traffic mrha BRZ First-Gen (2012+) — General Topics 39 06-01-2017 02:15 PM
Traffic Tickets Anyone? SocalBurt Scion FR-S / Toyota 86 GT86 General Forum 325 04-18-2016 06:51 AM
Dangerfield is in the traffic newft86 AUSTRALIA 12 06-25-2012 08:57 PM
Traffic Nav Not working on my BRZ Indestruct Electronics | Audio | NAV | Infotainment 9 06-19-2012 09:38 PM
