Old 08-14-2016, 11:39 AM   #1
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
Weird electrical problem
Hey everyone, so last night while driving I noticed my fog lights weren't on even though the fog dash light was illuminated. I came out of the car to check the fogs and I noticed none of the parking lights were working. I checked the fuses for "TAIL" as that fuse is for the parking lights. It was blown, so I replaced it with the same fuse and it instantly blew. I tried a bigger fuse and the fuse started smoking up. I also took a look at the fog light fuses and both the left side and right side fuses were fine.
Anyone have any idea what's going on? A short or something?
Sent from my LG-H811 using Tapatalk
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Old 08-14-2016, 11:41 AM   #2
Using all stock bulbs? Do anything lately that could have pinched a wire? Parked in a field where there could be rodents (not a joke)?
Old 08-14-2016, 12:28 PM   #3
itsAlex
itsAlex's Avatar
The only stock bulbs are the side markers and the DRLs, everything else is LED. When I changed my licence plate bulbs to LEDs I had to increase the TAIL fuse a few amps, it's been like that for about 3 months. My fogs are also LED and only consume about 20w each, which is way less than what the stock fogs pull.
I'll take a look in the trunk for any pinched wires, my subwoofer box does tend to slide around time to time, maybe it pinched something who knows. Either that or a faulty/shorted LED bulb I guess
Old 08-14-2016, 12:51 PM   #4
Not just the amps to consider. You may have blown a ballast for the LEDs. I would start there before tracing to many wires.
Bristecom (08-14-2016)
Old 08-14-2016, 01:52 PM   #5
itsAlex
itsAlex's Avatar
I figured it out, one of the licence plate bulbs went bad:
It created a short which melted the wiring at the bulb harness:
I'm going to repair the harness and get a replacement bulb. I replaced the fuse and everything works again, even the fogs. It seems that somehow the TAIL fuse is also linked the the fog lights' functionality somehow, as I experimented and found that when the TAIL fuse is blown/missing, the fogs won't turn on.
The Following 2 Users Say Thank You to itsAlex For This Useful Post:
jcw99 (08-14-2016), Tcoat (08-14-2016)
Old 08-14-2016, 02:11 PM   #6
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
When I read the above, I immediately knew the following:
When going from the stock LP lights to the LEDs the current should NOT have gone UP.
And when I read that you had a problem but just kept putting bigger & bigger fuses in, I was tempted to be an ass and say "just stick a penny in it!"
@Tcoat will know what I am talking about
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
Cole (08-14-2016)
Old 08-14-2016, 02:15 PM   #7
humfrz
Moral support from @Tcoat ......... and you figured it out ........
humfrz
Ultramaroon (08-14-2016)
Old 08-14-2016, 02:23 PM   #8
humfrz
YIKES! ...... are you behind times .......
Yes, for house type fuse boxes, we used to put a penny behind the fuse.
For older automobiles, we would put a spent .22 cal cartridge in the fuse slot.
However, with todays fuse blocks, the redneck way is to jump the fuse slot with a piece of bailing wire.
THEN, go looking for the smoking electrical piece ....... while having a beer .....
humfrz
The Following 4 Users Say Thank You to humfrz For This Useful Post:
finch1750 (08-15-2016), justatroll (08-14-2016), Ultramaroon (08-14-2016), zberz (08-16-2016)
Old 08-14-2016, 02:30 PM   #9
Chimera
Drives: FRS
humfrz
SO.. You jest.. However I had a short happen in some of my custom wiring and eventually did just that on an unloaded circuit to see if it still shorted and went hot as I was out of fuses to blow. Did eventually trace the short to a DC head which I guess shorted inside the male connector head.
The Following User Says Thank You to Chimera For This Useful Post:
humfrz (08-14-2016)
Old 08-14-2016, 03:56 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
...I was tempted to be an ass...
...because YELLING your explanation wasn't CONDESCENDING enough?
Old 08-14-2016, 04:02 PM   #11
justatroll
justatroll's Avatar
...because YELLING your explanation isn't CONDESCENDING enough?
SOMEtimes I use ALL CAPS, and sometimes I use BOLD.
One thing I AM Certain of is that it is MORE anOYYing when people bitch about IT.
And I HARDLY THINK USING TWO WORDS IN CAPS CONSTITUTES YELLING
I mean it COULD be worse
The Following 2 Users Say Thank You to justatroll For This Useful Post:
Cole (08-14-2016), Ultramaroon (08-17-2016)
Old 08-14-2016, 04:14 PM   #12
humfrz
Oh come on you two. We all know that old school automotive fuses required cigarette pack foil wrapped around them when they blew.
I do recall a moment of fear when a buddy was having issues with the fuses in his AMC Javelin. He said he kept blowing fuses and asked if I could take a look. Crawled up under the steering column where the box was, took one look and rapidly exited and unhooked the battery. Apparently he did not grasp the concept of what a "spent" cartridge was and there about 14 inches from his crotch was a full .22 LR round crammed into an over heating brake light circuit.
Old 08-14-2016, 05:45 PM   #13
Ultramaroon
not playing cards
Yeah but if it blew, he'd've known it.
Stu, you're one special snowflake.
fify
Old 08-14-2016, 08:01 PM   #14
justatroll
justatroll's Avatar
fify
Says the self declared asshole...
I thought we always got along
Really weird problem: Have to fill with fuel very slowly Kido1986 Issues | Warranty | Recalls / TSB 31 08-20-2017 11:11 AM
Electrical Issues fuzzybat23 Issues | Warranty | Recalls / TSB 10 12-13-2014 05:51 PM
Weird electrical issues. Need help! Pneub Issues | Warranty | Recalls / TSB 15 09-13-2014 12:38 AM
weird problem during traffic jam yesterday Minovsky Engine, Exhaust, Transmission 39 05-14-2014 01:46 AM
Electrical system EDCOVEY Issues | Warranty | Recalls / TSB 0 11-26-2012 11:45 PM
