Old 12-16-2019, 11:04 PM   #1
SamtheKorean
September
SamtheKorean's Avatar
Drives: 2015 BRZ
Need help extracting drain plug...
so i bet everyone had this kind of situation before, stripped or rounded nuts or bolts. over the weekend I decided to do an oil change it was lil bit rounded to start with but i only had 12points 14mm for 1/2 drive so just said f@#k it and used it. welp it didn’t end well, i’ve ordered fumoto valve for future oil changes but for my stuck drain bolt should i pick up a 14mm 6 point socket or bolt extractor special tool? just trying to see what y’all can add or give me some tips.
SamtheKorean is offline   Reply With Quote
Old 12-16-2019, 11:28 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
First thing I would try is getting a 6pt and hammering it onto the bolt till it is fully seated. Don't jerk on the ratchet, just gradly increase pressure. That thing shouldn't be so tight that it won't come off that way. Your next bet is going to be a big set of vice grips. Good luck.
Old 12-16-2019, 11:30 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'd go the bolt extractor route. usually the quickest.
but it won't get it to tighten back on...
Old 12-17-2019, 12:28 AM   #4
qqzj
Drives: MDX, Camry
If you can get a good grip, a big channel lock or vice grip might work. Otherwise, left-hand bolt extractor is the best
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
Old 12-17-2019, 01:34 AM   #5
alan.chalkley
Drives: 4wd zooks
I had the same problem after "talented dealer technicians" performed oil changes for six years.
The solution was to gently tap a six point socket over the oil drain bolt and carefully use a long handle for more torque.
Use a new crush washer and use a torque wrench to replace it.
alan.chalkley is offline   Reply With Quote
Old 12-17-2019, 01:38 AM   #6
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Bolt out/damaged bolt removers should do the trick if you’re ok with buying some new tools to add to your collection
https://m.sears.com/craftsman-10-pc-...SABEgJxa_D_BwE
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 12-17-2019, 02:10 AM   #7
Here ya go -
OR, Bubba suggests you take a cold chisel and a big fucking hammer and cut into and hammer on the side of the plug, in a counterclockwise direction, till it loosens up (since you ain't gonna use it no more anyway).
Old 12-17-2019, 10:06 AM   #8
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Everyone has good suggestions already.
Remove that splash panel if you haven't for more access. I'd use big vice grips first, then hammer on the 6 point with a long breaker bar. I personally haven't used those socket extractors yet but they look promising. I did try to use the drill bit extractors for smaller bolts but that didn't work.
Clueless
YamahaR86 is offline   Reply With Quote
Old 12-17-2019, 11:13 AM   #9
SamtheKorean
September
Drives: 2015 BRZ
picking up a 6point socket today and hope for the best, already tried huge channel lock for pluming but still couldn’t get it.. maybe vice grip is better after all
Old 12-17-2019, 11:21 AM   #10
chickunfut
Low-Buck Ramp Truck
chickunfut's Avatar
Drives: 2016 Scion FR-S Release 2.0 #502
Turn it the other way...
chickunfut is offline   Reply With Quote
Old 12-17-2019, 11:26 AM   #11
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Yeah, think you're going to need something with more bite or longer handle like a breaker bar/extending ratchet for the torque since it's on there tight.
Clueless
Old 12-17-2019, 12:11 PM   #12
SamtheKorean
September
Drives: 2015 BRZ
i know lefty loose righty tighty haha but i did try going the opposite direction just in case if the bolt was frozen frozen stuck
Old 12-17-2019, 12:12 PM   #13
SamtheKorean
September
Drives: 2015 BRZ
i have a 15in breaker bar but harbor freight opened up in local location so i’m picking up 25in breaker as well.👍
Old 12-17-2019, 12:21 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That should do it, gradually increase pressure. Watch the socket, if you see it start turning and the base of the bolt head isn't moving I would stop. Best to go to an extractor at that point.
Quick Drain Plug dholloway543 Engine, Exhaust, Transmission 29 11-14-2019 01:08 PM
Why isn't there a 2nd drain plug on the bottom of AT oil pan? FT86.ca Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 03-04-2017 08:40 PM
Drain plug leaking...what to do... OUGrad05 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-28-2016 02:01 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Oil Drain Plug Size jjkerr626 Engine, Exhaust, Transmission 3 11-28-2014 06:20 PM
