Old 12-02-2019, 06:16 AM   #15
MobiusOne
Drives: Toyota GT86 HKS Supercharged
Originally Posted by gpvecchi View Post
Actually I'm converting the car to JDM specs (final dŕve, red manifold and intake, and header), so I prefer to flash a full ROM, for the gear indicator and the completely different AFR...
I don't understand the purpose of this conversion, but if you don't want to sell the car in Japan (convincing the buyer that is a JDM spec ) a revised tune done by a reputable shop is better.
MobiusOne is offline   Reply With Quote
The Following User Says Thank You to MobiusOne For This Useful Post:
wparsons (12-05-2019)
Old 12-04-2019, 09:48 PM   #16
steve99
Drives: FT86
Originally Posted by solidsnake11 View Post
Does anybody know where to download the RR def for oft A01C with ffs and lc.
You also need the A01C rom with the lc\ffs patch as well as the def
You could use B01C or A01G. As substitute
Or do you want a genuine A01C ??
solidsnake11 (12-04-2019)
Old 12-05-2019, 06:16 AM   #17
gt7877
Drives: turbo frs
I may need to turn off the codes for the direct injection in a little while and the A01g I'm using doesn't have it.
I think I have the rom for A01C ffs and lc.
U can download it from openflash site
And use stive xml to modify it
gt7877 is offline   Reply With Quote
Old 12-05-2019, 11:32 AM   #18
tomm.brz
Drives: brz 2017 hksv2
I guess you can use those Defs that works to disable the DTC you want to disable, save it and then open it again with other more complete defs
solidsnake11 (12-05-2019)
Old 12-05-2019, 04:10 PM   #19
steve99
Drives: FT86
I may have to use a stock A01C def rom.
OFT doesn't have the diagnostic codes for the direct injection defined.
Check the rom with hex editor make sure all three calid strings are A01C before you use a romraider A01C def to edit
The first two strings ate 8000 and 10000 are often changed buy oft guys indicating a hacked rom, the third string at about 11000 is the real calid. If all three are not the same the rom is calid modified
Before you edit check some known tables like base timing and open loop fuel tables make sure they look ok if not def is not matched
Old 12-12-2019, 03:10 AM   #20
steve99
Drives: FT86
I looked at the addresses of some of the other dtc and evedently oft is not based on the A01C even though it says it is.
Yes for example if first two are A01C and third one is B01C or A01G then the rom is a calid hacked and is rearly based on the third calid
solidsnake11 (12-13-2019)
ZA1JA01C PolishFrs13 Software Tuning 26 02-22-2022 12:33 AM
Stock ROM for ZA1JB01C MotoGrapher Software Tuning 2 05-01-2019 01:49 AM
ZA1JA01C True reliability forwallblakmail Software Tuning 41 03-13-2014 03:41 AM
