Old 04-30-2019, 10:51 PM   #1
MotoGrapher
Drives: 2014 White BRZ Limited
Stock ROM for ZA1JB01C
Hello guys, I'd like to copy&paste some numbers from the stock ROM to the V4 tune. I download the ZA1JB01C.ori file from OFT directly but could not open it correctly. It gave me all sorts of errors in RomReider.
Do you guys know how to find the correct stock ROM for ZA1JB01C? When I open it, what def should I use?
Thank you very much!
MotoGrapher is offline   Reply With Quote
Old 05-01-2019, 12:40 AM   #2
jflogerzi
jflogerzi's Avatar
Did you grab the definition file?
2013 Series 10 FRS #553
Old 05-01-2019, 01:49 AM   #3
steve99
As above you will need a romradier def for stock B01C as a oft tuned B01C is actually an A01G altered to look like B01C, hence the problem you have.
Read the romraider tips link in my signiture below
You will need to get a B01C def from github
Then make sure correct def is a top in list in romraider when you open the stock and tuned roms
FS: Stock brake lines, stock clutch line, stock motor mounts Agent_D Brakes, Suspension, Chassis 4 08-22-2017 12:24 PM
**Prodrive: GT1 ALL In Stock!!** Enkei: RPF1, T6S, Konjin, TSP6, Raijin ALL in STOCK OAKOS Automotive Wheels and Tires 290 03-01-2016 10:32 AM
FS: Openflash, Weathertechs,Mtech Trasmission Springs, Stock Exhaust, Stock intake Brahsbrah Canada Classifieds 11 11-09-2014 11:03 AM
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 09:22 PM
