Old 03-21-2015, 08:56 PM   #1
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
ZA1JA01C
Can someone Email me the Stock ECU rom file "ZA1JA01C"
i have used the ZA1JB01C and it isnt working i want to try the different file rom before i go to different conclusions.
PM for the Email address.
please and thank you
PolishFrs13 is offline   Reply With Quote
Old 03-22-2015, 02:18 AM   #2
steve99
here is stock ZA1JA01C rom file just unzip it
attached a ZA1JB01C as its the latest rom compatable with your car if it originally cam with a A01C rom.
What do you mean "its not working"
rom will not open in romraider or tables look weird
your car is no longer working
What flashing device are you using ??
Old 03-22-2015, 02:10 PM   #3
PolishFrs13
building life
Im trying to flash it back to Stock after just removing my turbo kit. It turns over but doesnt start.. Im using ECUtek
Old 03-22-2015, 06:47 PM   #4
steve99
It more likely a hardware problem than the flash or rom especially if ecutek reported no problem with flash precess
any cel codes ?
will email unzipped roms.
Old 03-22-2015, 09:21 PM   #5
Skorov
Skorov's Avatar
Drives: 86 GTS White
Did you remember to replace your stock MAP sensor? I've made that mistake before. :-)
Skorov is offline   Reply With Quote
The Following User Says Thank You to Skorov For This Useful Post:
steve99 (03-22-2015)
Old 03-23-2015, 01:23 AM   #6
PolishFrs13
building life
I actually didnt.. double checked it lol and car still isnt starting
Old 03-23-2015, 01:24 AM   #7
Skorov
Skorov's Avatar
Car still isn't starting with stock MAP sensor and stock rom?
Old 03-23-2015, 03:41 AM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
any cel codes ?
ECUtek won't let you flash incompatible ROMs. It is likely to be hardware rather than the ECU.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-24-2015, 04:29 PM   #9
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Yeah you need to flash a stock ECUTEK rom with ECUTEK. You can't use a factory stock rom file from anywhere else I believe. Once you have flashed a stock ECUTEK rom file you can flash anything over it you want.
Toyota John is offline   Reply With Quote
Old 03-24-2015, 10:19 PM   #10
PolishFrs13
building life
Nope
Old 03-24-2015, 10:20 PM   #11
PolishFrs13
building life
Anyone have the ECUTEK Stock ROM file they can email me ?
Old 03-24-2015, 10:26 PM   #12
Skorov
Skorov's Avatar
There should be a bunch in your EcuTek folder. When you go to flash the ECU, there's a box that tells you which roms are compatible with your car. Choose one of those.
Sorry I can't be more detailed, I don't have my EcuTek laptop in front of me. If you need help, I'm happy to do so in about 5 hours when I'm home.
Old 03-26-2015, 12:47 AM   #13
PolishFrs13
building life
I already tried the only one compatible with my car and no starts. Cranks that's about it everything else is good and oem stuff is on
Old 10-12-2019, 04:09 PM   #14
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
Hello Steve,
This is old thread buy I got a question.
I am trying to flash a friends car back to stock using ECUteck, He was originally tuned on ECUtek as he was boosted. I flashed the recommended or downloaded files Ecutek provided. Flash went okay but the car wont start. It will crank and start but then dies immediately. We checked everything in the car.
Our assumption now is the tune. I was wondering if I can use this tune in the the link to flash back to stock? His CAL ID is A01C. the B01C will flash okay?
Thanks.
Kayysonie is offline   Reply With Quote
ZA1JA01C True reliability forwallblakmail Software Tuning 41 03-13-2014 03:41 AM
