Old 07-20-2012, 07:35 AM   #1037
nix
nix's Avatar
Drives: AVO BRZ
Originally Posted by Don@Accelerated View Post
Absolutely
Cool, looking forward to it.
There are some hurdles to an AP rhd kit, on the tune side we run different fuels, on the kit side I think the fmic hot side, intake and downpipe/turbo section would need redoing and probably needs an internally gated turbo and plumbed back BOV.
nix is offline   Reply With Quote
Old 07-20-2012, 07:40 AM   #1038
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Nix how much power r u chasing?........ I will want atleast 350rwhp.... Run no cat and prefer single exhaust over twins..
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
Old 07-20-2012, 08:10 AM   #1039
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Fenrir View Post
Did the turbo or the tune eliminate the torque valley? I like how much flatter the line is. A lot.
The turbo did. The valley is caused by intake resonance which results in a low volumetric efficiency at that rpm range.
Old 07-20-2012, 08:43 AM   #1040
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Warranty <<< vs >>> Moar powah!
I pity you guys in the States as much as I envy you for having this awesome kit to consider now.
Luckily I don't have a good ECUtek tuner anywhere near me in Dubai so this kit is probably a no-no for me.
That torque. That power curve. Perfect.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 07-20-2012, 08:52 AM   #1041
sierra
Drives: Skoda Yeti DSG diesel 4x4
Is that theory or have you got some evidence the torque dip is caused by intake resonance?
It just doesn't make sense that they would have built a crap intake to cause that. Someone mentioned emissions and tuning specifically at that rpm range to satisfy euro? requirements resulting in a power loss. That makes more sense and an ECU tweak would soon fix it up.
sierra is offline   Reply With Quote
Old 07-20-2012, 09:01 AM   #1042
Don@Accelerated
Don@Accelerated's Avatar
Its like 75HP on the big end. I don't plan on stopping at 4psi. I really thought even w/ the high compression we would be around 8 and 12-14 w/ e85 or methanol injection. We will wait and see til we can turn it up.
Originally Posted by inz View Post
I understand the costs involved, the R&D associated with all of the modification necessary to make more power out of an already high strung engine like the F20. I respect the work Don has done and commend him for being so open and forward with a lot of information other manufacturers/developers/mechanics and tuning houses would keep private.I also have no doubt that what Don asks for this kit will be a very fair price...
But it's a lot of money for 50hp.
Don@Accelerated is offline   Reply With Quote
Old 07-20-2012, 09:02 AM   #1043
Don@Accelerated
Will most likely move the compression to 10-10.5. Seems to be a good area we use in alot of other cars. You'll have alot of low end grunt and still be able to maintain alot of cylinder pressure.
-Don
All valid points. Longevity may play a factor in how far the buck can be pushed - but that's part of the reason it's so great that a few guys in the know are pushing the limits.
Don, with high HP targets and the pistons you plan to use for forged builds etc, will you be lowering the compression ratio?
Old 07-20-2012, 09:03 AM   #1044
Don@Accelerated
Without alot of RHD pictures I don't know. Let me see some!
Originally Posted by JP View Post
so this wont fit in a RHD car with the steering column, brake booster/clutch master etc in the way will it?
Old 07-20-2012, 09:05 AM   #1045
Don@Accelerated
We'll have this ironed out very well that a simple flash tune will work just fine.
Old 07-20-2012, 09:08 AM   #1046
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Keep in mind with this thing's low weight 50hp gives it the same lb/hp as a stock STI, and with RWD too much power will mean you have to uprade a lot of other things that will just add weight and diminish returns. Personally I think the way he has it now is perfect. Nice flat torque curve, should spool instantly, just enough of a power bump to make it snap your neck back but not so much to make it impossible to control.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
The Following User Says Thank You to Spaceywilly For This Useful Post:
MannyO (07-20-2012)
Old 07-20-2012, 09:56 AM   #1047
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
I thankyou don for giving us such great news and just in time for my birthday!
Exhaust is offline   Reply With Quote
Old 07-20-2012, 10:01 AM   #1048
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
Jalopnik
Normally this would be a good thing, but you got on Jalopnik. They confused crank with wheel hp and gave a disappointing review. I set 'em straight with it and they edited their article, but just changed the number. hopefully they'll edit the whole thing and realize how awesome this is. http://jalopnik.com/5927631/the-firs...-13-horsepower
thejevans is offline   Reply With Quote
Old 07-20-2012, 10:25 AM   #1049
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
Good to know I'm not missing anything over there... stopped reading that junk a few years ago
civicdrivr (07-22-2012)
Old 07-20-2012, 10:44 AM   #1050
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
Changing the intake won't effect the dip, and no one has posted any ability to remove the dip completely with a tune, either.
I don't know enough about intake resonance to comment further, but I am sure someone has more info to enlighten us all.
Symbiont is offline   Reply With Quote
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
