Old 09-30-2019, 08:52 PM   #1
pevsfreedom
Drives: 2014 BRZ
New engine question
Let me start off by saying I don't know anything about engines; my friend is helping me do an engine swap. My old one threw a road and is toast.
So I got this new engine in off eBay and we're perplexed as to what they did here:
(Old engine):
(New engine):
1) This obviously has some purpose (bridgestone nipple)?
2) Janky green hose
3) Weird splice?
4) And this welded on (I think?) nipple (capped) that is nowhere to be found on my old engine. It appears as if the hose connects to it?
Anyone know what they did here?
pevsfreedom is offline   Reply With Quote
Old 09-30-2019, 08:55 PM   #2
pevsfreedom
Drives: 2014 BRZ
Other friend showed me it may be a set-up for an air oil separator?
Old 09-30-2019, 09:15 PM   #3
86TOYO2k17
Drives: 2017 toyota 86
Is this off an auto?
1. Looks like nipple added for boost line for boost gauge, autos usually cap that nipple since not used for brake booster. But can use for boost gauge.
2. Janky green hose not sure cant tell where its going to or from by picture.
3. Splice possibly for catch can and or something to do with turbo. Again hard to tell without seeing all ends.
4. Tapped most likely for Oil temp and or pressure.
All signs point to this being off a turboed car and possibly an auto.
Also, thought about just stripping the manifold and hoses, and swapping yours on?
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
pevsfreedom (09-30-2019)
Old 09-30-2019, 09:17 PM   #4
pevsfreedom
Drives: 2014 BRZ
Manual. I think the plan is to just put it all back stock like the old one - I'm just mostly curious about that nipple that's capped off that my old engine doesn't have (#4). Can just leave it capped? Sounds idiotic I'm sure? Not sure if I can get better pictures or explanations really as I don't know what anything is called The hose in 2 goes under the black piece and goes into the splice (3), which one side connects into the engine and the other is the loose hose in 4.
Old 10-01-2019, 12:21 AM   #5
solidsnake11
Drives: brz
Hopefully, they just added a crankcase breather for the heck of it, if not, you may have a nice smoke show when you get it installed.
solidsnake11 is offline   Reply With Quote
Old 10-01-2019, 01:46 PM   #6
pevsfreedom
Drives: 2014 BRZ
Any other ideas as to what's going on with the capped off nipple in image 4? The person I bought off eBay says it's "completely stock" which uhh it's not so I'm a bit desperate trying to figure this out.
Old 10-01-2019, 01:51 PM   #7
http://www.ft86club.com/forums/showthread.php?p=2712903
Old 10-01-2019, 01:57 PM   #8
pevsfreedom
Drives: 2014 BRZ
and this being my old stock engine:
Old 10-01-2019, 01:59 PM   #9
pevsfreedom
Drives: 2014 BRZ
I was concerned about that. They 'assured me' it's off a manual.
Old 10-01-2019, 02:18 PM   #10
pevsfreedom
Drives: 2014 BRZ
My biggest question is if shit'll start blowing out the bronze piece if I install it or if I can just cap it and leave it alone and swap to original hoses. Like someone mentioned earlier I'll just try and swap the manifold and hope problem solved, but I am still so curious;
The Following User Says Thank You to pevsfreedom For This Useful Post:
Tcoat (10-01-2019)
Old 10-01-2019, 02:33 PM   #11
Just swap out the AT parts for the MT ones. The bigger concern (don't want to scare you but it has to be said) is what shape the engine is actually in. If the lied/were mistaken about it being from a MT then who knows what else isn't right about it.
pevsfreedom (10-01-2019)
Old 10-01-2019, 02:34 PM   #12
pevsfreedom
Drives: 2014 BRZ
Maybe I missed the point in your last post but are you saying for sure that this is from an AT engine? Any idea about the bronze "nipple"? I wish I knew more but I'm still running under the assumption it is an MT engine.
Old 10-01-2019, 02:47 PM   #13
Of course we can't see the engine from all angles (and I can't look at the pics at work anyway) but from your description it sounds all the world like an AT set up. I could be wrong of course because I am going with the limited info I have at hand.
86TOYO2k17 (10-01-2019), pevsfreedom (10-01-2019)
Old 10-01-2019, 03:00 PM   #14
Take a look at the engine and see if it has the vacuum pump on the rear passenger side (Step 12 below). If it does it is an AR if not it was MT. The plumbing may be for an oil cooler. If so the nipple that you are concerned about may be unusual.
Question about engine knock? chaoskaze Engine, Exhaust, Transmission 12 06-09-2016 05:49 PM
BRZ Blown engine question Mujen84 Forced Induction 118 04-02-2014 05:04 AM
Engine Oil Question wodnr1215 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-12-2013 10:42 PM
Engine Noise Question TONYpepperon1 Issues | Warranty | Recalls / TSB 13 09-01-2013 05:22 AM
Engine Question alex05 Engine, Exhaust, Transmission 4 02-21-2012 06:08 AM
