Old 09-16-2014, 06:43 AM   #1
nEEdLzZz
Drives: Honda Civic Type R (FN2)
Question is there a oil temp sensor installed from factory?
if there is one installed, how can i get the readings?
i basically just wanna know when the oil is up to temp and i can start revving it..
i heard that you can get the readings by just using an app for iphone/android. is that correct?
which app do you recommend?
thanks in advance for your answers!
nEEdLzZz is offline   Reply With Quote
Old 09-16-2014, 07:10 AM   #2
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
I actively monitor with my openflash tablet everyday, so the answer would be a yes. I'm fairly certain the Bluetooth obd2 adapters and certain programs will monitor it as well.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 09-16-2014, 07:34 AM   #3
mikepaul21
mikepaul21's Avatar
Drives: 2013 Subaru BRZ
you could just wire up a cheap mechanical gauge to your oil gallery plug and always have it viewable.
mikepaul21 is offline   Reply With Quote
Old 09-16-2014, 07:56 AM   #4
Foobar
SLO NO MO
Foobar's Avatar
The sensor can be read via the ECU, so any gauge or datalogger that can talk OBD2 should do it. On Android or iOS you can try Torque or Dash Command along with an OBD2 dongle.
Old 09-16-2014, 08:16 AM   #5
nEEdLzZz
ok, so all i really need is an OBD2 dongle and the app?
which dongle do u guys recommend?
Old 09-16-2014, 09:28 AM   #6
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Torque app and bluetooth adapter off Amazon will work fine.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 09-17-2014, 04:21 PM   #7
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
PUll out your OBD2 adapter if you leave it parked for awhile though, that's not switched power and it will drain your battery in a couple weeks' time.
DoomsdayJesus is offline   Reply With Quote
The Following User Says Thank You to DoomsdayJesus For This Useful Post:
juliog (09-17-2014)
Old 09-17-2014, 04:35 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
OBD port like what others have mentioned.
http://www.ft86club.com/forums/showthread.php?t=59426
-alex
Old 09-17-2014, 06:38 PM   #9
Turbowned
Turbowned's Avatar
I believe the P3Cars digital vent gauge can monitor it as well as other parameters; it plugs into the car's OBD port.
Old 09-17-2014, 06:52 PM   #10
extrashaky
Drives: 2014 BRZ Limited
The ScanTool LX and MX adapters shut off automatically to avoid draining the battery, but they're not cheap.
I'm using Torque and have both a dial gauge and digital readout as part of my main screen:
The Following User Says Thank You to extrashaky For This Useful Post:
DoomsdayJesus (09-18-2014)
Old 01-04-2019, 07:29 PM   #11
e_lunatic
Drives: 2015 Scion FR-S
I have the OFT v2 but haven't seen anything that shows the oil temp in the diagnostics. did they do away with that feature or am i just a dummy and not seeing it?
e_lunatic is offline   Reply With Quote
Old 01-04-2019, 07:45 PM   #12
Brink
Drives: 2017 BRZ
Trade it in for a '17+.
Brink is offline   Reply With Quote
The Following 2 Users Say Thank You to Brink For This Useful Post:
gravitylover (09-14-2019), NCtoBRZ (01-05-2019)
Old 09-14-2019, 04:11 AM   #13
_keepkushin_
Drives: 2013 subaru brz limited
you would more than like have to run a sandwhich adapter to get a reading as i am currently using torque pro and it does not have a eot sensor widget i would suggest looking into a mount and a custom gauge to your liking.
_keepkushin_ is offline   Reply With Quote
Old 09-14-2019, 11:14 AM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
my scanguage ii has a oil temp sensor readout. you need to either update your PID's, or get different software.
Eng coolant temp sensor location D K Engine, Exhaust, Transmission 28 08-27-2014 06:30 PM
Addition of a radiator hose sensor temp adapter & coolant bleeding FutureFT86 Engine, Exhaust, Transmission 9 07-22-2014 12:50 AM
p0198 code oil temp sensor malfunction circuit high kingkai23 Forced Induction 10 06-17-2014 02:22 PM
OEM Oil Temp Sensor Location Khorne Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-15-2014 11:38 PM
Dealer installed alarm shock sensor 1stGenBRZ86 BRZ First-Gen (2012+) — General Topics 2 07-19-2013 11:20 AM
