Drives: 13 swp limited
p0198 code oil temp sensor malfunction circuit high
Finised my jdl turbo install started her up then threw that code...bad sensor? installed tee wrong? Any ideas
Did you wrap it in Teflon tape. You may have used too much and now the sensor isn't grounded through the block any more
Sent from my SPH-L710 using Tapatalk |
I used thread sealer
Did you leave some of the threads , on both the adapter and the sensor, uncoated?
Ill play with it tonite thanks man
NASA SpecE30 Racer
The obvious question would be did you hook the spade connector back on to the sending unit.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Yes its hooked up
Ever get this cleared up?
#10 |
I should find out tonite..i forgot to put the fitting that goes to the tee and block because i didnt see the fitting hiding in the box..i put the tee directly in the block i hope that was caused the code
#11 |
ah good luck man, just started mine up for the first time last night
| Scangauge oil temp xgauge code [Working] | pkny | Engine, Exhaust, Transmission | 125 | 12-26-2022 11:11 AM |
| FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) | AtlasMick | Interior Parts (Incl. Lighting) | 2 | 03-31-2015 05:47 PM |
| OEM Oil Temp Sensor Location | Khorne | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 01-15-2014 10:38 PM |
| STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB | ziptiedae86 | Interior Parts (Incl. Lighting) | 0 | 10-29-2013 11:50 PM |
| Volunteers to help install my high temp brake fluid and pads with me? | stockysnail | Northwest | 9 | 07-22-2013 05:15 PM |
