Old 07-19-2013, 03:57 AM   #1
1stGenBRZ86
1stGenBRZ86's Avatar
Dealer installed alarm shock sensor
I had the shock sensor for the alarm installed by the dealer before I picked up my car. It definitely works, just seems too damn sensitive. Does anyone else have this option? It seems like the slightest wind sets off a series of horn beeps (that go off before the alarm starts ringing). Is there anything I can do to lessen the sensitivity? I don't want to completely disable it.
1stGenBRZ86 is offline   Reply With Quote
Old 07-19-2013, 03:57 AM   #2
Itssrayyxd
Drives: Scion frs.
Same problem here
Itssrayyxd is offline   Reply With Quote
Old 07-19-2013, 10:20 AM   #3
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
As someone who used to install car alarms; shock sensors are a great way to give yourself and your neighbors a headache.
They are either too sensitive, or useless.
You could check the service manual to find the location of the sensor; they usually have a dial on them (you'll need a pretty small flat head). If it isn't physical, you'll need the obd2 cable + the software for adjusting car parameters. You can search the forum; some people like to change the door chime/etc, and I think the same software would change this.
GeorgeJFrick is offline   Reply With Quote
What aftermarket Alarm did you buy and where did you get it installed? bear89103 Southern California 25 07-12-2013 12:53 AM
Dealer Installed Borla Exhaust TaddyDobbins Engine, Exhaust, Transmission 7 02-18-2013 12:26 AM
Dealer installed fog lights? TommyFive BRZ First-Gen (2012+) — General Topics 2 02-07-2013 11:17 PM
Any pre-installed options when car arrives at Dealer? frs23 Scion FR-S / Toyota 86 GT86 General Forum 28 05-22-2012 03:57 PM
Dealer Installed Badges ToyotaObsession Scion FR-S / Toyota 86 GT86 General Forum 55 05-14-2011 12:16 AM
