Old 09-08-2019, 02:52 AM   #15
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Originally Posted by GrantedTaken View Post
I bled the brakes on the BRZ.
I was worried that the stud would shear again
but all lug nuts came off easily b/c of anti-seize last time.
I did about 10 pumps for the rear,
and 5 pumps for the front.
Brakes seem to be more firm, but still not hard & biting.
I think rotors are scored, and
I think the pads are low, but I can’t even see.
I literally had the wheels off, and I have no clue if the pads are low.
There is no where to see the pad. Totally blocked views.
How are you supposed to see if your pads are low?
If you want to inspect the pads: undo the caliper guide pin and spin the caliper body away from the bracket. You can also peer into the channels of the caliper body.
Hard to say anything about your rotors or pads without pictures. Could be glazing. You'll have to spin the caliper if you want to pull the pads and inspect the surfaces
Rotor scoring can be normal depending on the extent.
EndlessAzure is offline   Reply With Quote
Old 09-08-2019, 10:30 AM   #16
GrantedTaken
Wow, I can't believe you need to remove calipers just to inspect the pad thickness.
Every other car I've owned, the pads are in plain view.
GrantedTaken is offline   Reply With Quote
Old 09-08-2019, 10:34 AM   #17
Tristor
Tristor's Avatar
If you have PP Brembos you can inspect through the top, but single piston calipers are full body cast on most vehicles so you have to remove the caliper to get a good reading. If you have the right tool you can check it without removing the caliper, but most folks don't have an outside micrometer laying around and you won't be finding one at Harbor Freight.
Unless every vehicle you had before had pinned pads (Brembos or simlar), you would need to have removed the caliper to get a good reading.
You can visually inspect without removing the caliper, but that doesn't really tell you much other than a broad answer.
Tristor is offline   Reply With Quote
Old 09-08-2019, 11:45 AM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You could always just stick your phone down under the front of the caliper to take a picture. I can see the stock rears just fine with the wheel on.
Clutch fluid won't bleed. ML Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-19-2018 08:35 AM
DIY : How to bleed your brakes justinco DIY (Do-It-Yourself) Guides 4 09-05-2017 02:40 PM
How often do i need to change/bleed brake fluid (DoT 5.1) dejxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-15-2015 11:50 AM
Innovate Stage 2 intercooler bleed bakilman Forced Induction 4 06-13-2014 02:48 PM
Bleed air from radiator/cooling system? OnionTou Engine, Exhaust, Transmission 2 03-28-2014 08:54 PM
