Old 06-13-2014, 10:38 AM   #1
bakilman
bakilman's Avatar
Drives: White FR-S
Innovate Stage 2 intercooler bleed
I'm not really confident that I have removed all of the air from the intercooler plumbing. I was hoping someone could offer any tips/tricks as to bleeding the system to remove all the air. I tried searching without any luck. Thank you!
bakilman is offline   Reply With Quote
Old 06-13-2014, 10:42 AM   #2
swift996
swift996's Avatar
Squeeze the lines for a long time, they should have put a bleeder somewhere on the system. If I remember keep the cap off and squeeze as much air out of the lines manually,.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-13-2014, 01:08 PM   #3
Fear
Drives: Ft86
You could always take it to a airconeitioning ahop and have then pull a vacuum through the bleed for 20 minutes then fill through the bleed with your coolant...
Kinda like some people do with the radiator
Fear is offline   Reply With Quote
Old 06-13-2014, 02:41 PM   #4
xxscaxx
Drives: 2013 SWP BRZ
squeeze the lines a LOT. Turn the car to "on", let the water pump turn on, keep squeezing. The pump should not make any kind of gurgling sound once the air is out, should be a slight hum.
xxscaxx is offline   Reply With Quote
Old 06-13-2014, 03:48 PM   #5
D K
Stig's dark passenger
If possible, place the pump at the lowest point in the system
D K is offline   Reply With Quote
PRE Intercooler stage 2 TC kit almost ready BRZPDX Northwest 57 04-04-2014 07:42 PM
Intercooler options for Sprintex/innovate diss7 Forced Induction 3 02-15-2014 10:03 PM
Innovate Stage 2 littletear Forced Induction 1 01-06-2014 07:51 PM
Innovate Motorsports Intercooler System and Upgrade! Innovate Motorsports Forced Induction 187 12-04-2013 04:26 AM
Innovate Stage 2 + e85, now what? KSpider Forced Induction 20 10-23-2013 10:51 AM
