Old 04-30-2014, 07:36 PM   #1
dejxx
dejxx's Avatar
Drives: FT-86
How often do i need to change/bleed brake fluid (DoT 5.1)
Quick question. I have done 2 track days, plus around 5.000km with Pentosin Racing Brake Fluid (DoT 5.1)... how often do i need to change/bleed this fluid??? Thanks!!!
dejxx is offline   Reply With Quote
Old 04-30-2014, 08:04 PM   #2
speargunsandracecars
Drives: 2014 BRZ
I do mine AT LEAST once every 6 months I run Motul RBF600, which is racing fluid, and is more prone to absorbing water. In general, racing brake fluids need to be replaced more often, even if mostly street driven. If tracked or autoXed regularly, even more often. If you're going to keep tracking your car, bleeding every 4-6 months, or when the fluid turns brown, or when it runs low, is a good rule of thumb.
speargunsandracecars is offline   Reply With Quote
Old 04-30-2014, 08:29 PM   #3
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Brake fluid can run low? :-B
Old 04-30-2014, 08:33 PM   #4
Malt
Drives: 2015 WRX
Yep, when you use up brake pads there is a "drop" in fluid level.
Malt is offline   Reply With Quote
Old 04-30-2014, 08:35 PM   #5
B-R-Z
B-R-Z's Avatar
Oh in that sense, yes.
Old 04-30-2014, 09:31 PM   #6
CSG David
CSG David's Avatar
How does your brake pedal feel? If it is not good, them change it. General maintenance from owner's manual requires change every year.
Old 04-30-2014, 09:38 PM   #7
dejxx
dejxx's Avatar
Drives: FT-86
brake pedal feels different (bit soft... brakes work well thou) if compare to how it was before the first track day... but that can be the pads and rotors right?
On an other fluid related question... Clutch feels a bit soft after the track days... nothing MAJOR, but a bit softer... what could be the reason for this?
Im a track noob, and even bigger mechanical noob... so sorry for dumb questions =)
Old 05-01-2014, 01:58 PM   #8
Tainen
Drives: First SWP BRZ-L
Most definitely just have some bubbles in your lines. No biggie, just bleed them. Firm pedal feel will return with a quick bleed job.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 07-11-2015, 10:22 AM   #9
cab33
Drives: Fast
Is there a trick to getting the brake fluid out of the reservoir?
A turkey baster just reaches the top 20%.
cab33 is offline   Reply With Quote
Old 07-15-2015, 11:50 AM   #10
fika84
fika84's Avatar
If you're bleeding the brakes than you will just run it through the lines.. you don't want to run the master cylinder dry..
You can use the turkey baster to get it down and then fill it up with new fluid and bleed the brakes until you have new fluid in all the lines.
fika84 is offline   Reply With Quote
DIY - Stainless Steel Lines - Speed Bleeders - Fluid Bleed/Flush F1point4 DIY (Do-It-Yourself) Guides 99 08-24-2017 06:05 PM
AT Fluid Change Terrapin77 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-29-2013 09:52 PM
DOT4 Brake Fluid Change and ABS Black Tire Tracking / Autocross / HPDE / Drifting 4 04-20-2013 06:24 PM
Fluid change siXXtoes Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-06-2012 09:39 AM
Brake caliper bleed order 96z2 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 10-12-2012 12:54 AM
