Old 09-17-2018, 11:30 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Clutch fluid won't bleed.
I'm trying to replace the clutch fluid and I have gotten very little fluid to come out of the bleeder valve. I took the banjo bolt off as well and fluid won't come out. The reservoir is a little bit before low and I have tried pressing the clutch with the valve open pumping the pedal but nothing..
Old 09-18-2018, 12:06 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Is your clutch pedal adjusted properly? Does the piston in the master cylinder fully extend?
ML (09-18-2018)
Old 09-18-2018, 07:05 AM   #3
ML
ML's Avatar
That is something I haven't thought of or checked.
Old 09-18-2018, 12:32 PM   #4
Ultramaroon
not playing cards
The piston must fully extend/relax in order to open the port to the reservoir.
ML (09-18-2018)
Old 09-18-2018, 01:39 PM   #5
Grady
Grady's Avatar
From you description is sounds like you are pumping while the bleeder port is open? This will get you no where.
Pump the pedal with the valve closed. Then while the pedal is depressed crack the bleeder to let the pressure/air/fluid out and then close. Then rinse and repeat till happy. Make sure the reservoir stays full.
The Following 2 Users Say Thank You to Grady For This Useful Post:
ermax (09-18-2018), ML (09-18-2018)
Old 09-18-2018, 01:43 PM   #6
ermax
ermax's Avatar
Here are the directions from the manual:
https://demos.starbase7.net/t3Portal...25614208530803
Key point: Never release the clutch pedal while the bleeder is open. That will just suck air into the system which isn't what you want to do. Also, never let the reservoar go empty.
The Following 2 Users Say Thank You to ermax For This Useful Post:
ML (09-18-2018), Ultramaroon (09-18-2018)
Old 09-18-2018, 02:58 PM   #7
ML
ML's Avatar
I'm pumping with the valve closed and then open it when the pedal is pressed and doing that process for 15 minutes no fluid is coming out. I'm going to get a vacuum bleeder and try to pull any air out.
Old 09-18-2018, 03:26 PM   #8
Ultramaroon
not playing cards
check that master piston adjustment. Normally, if that bleeder valve is left open, it'll just drain on its own.
Old 09-18-2018, 03:45 PM   #9
ML
ML's Avatar
I haven't gotten to mess with it since my initial post, but I'm will check it tonight and report back. thanks all
Old 09-18-2018, 07:19 PM   #10
gravitylover
You just made me think... (yeah it hurts ) Since my clutch job was done a few weeks ago I get the feeling that when I push the pedal in it's not releasing completely and sometimes if I'm not at a complete stop it's really balky going into 1st. Sometimes in heavy traffic you need to go in and out of gear and I used to be able to do it smoothly into 1st up to ~6mph. There's also a slight shudder if I can't release the pedal completely in gear and have to feather it. I noticed this morning before pulling out of the driveway that when I pushed the pedal down and put it in 1st the rpm's dropped a hair and it sounded different than when nothing was done. Should I assume the pedal needs a slight readjustment? Also they said they did a flush and bleed of the fluid but it's as black as it was before, should I just do it again (after the pedal is adjusted properly)?
Old 09-18-2018, 08:00 PM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I would suggest you do an adjustment and bleed the fluid just in case it's black as you said. But this job was completed by a shop you really should take it back to them and show them
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
gravitylover (09-18-2018)
Old 09-18-2018, 11:46 PM   #12
ML
ML's Avatar
I got my clutch working. Had to press the clutch pedal loosen the bleeder and press fork pin on the slave towards me to force air out. Then I put a hose on the bleeder with some fluid in it and opened the bleeder and slowly pressed the clutch. This also forced the rest of the fluid out.
Old 09-19-2018, 12:18 AM   #13
Ultramaroon
not playing cards
Did the fluid look lighter right afterward? If it did, then some of the crap along the bottom of the reservoir mixed in with the new stuff. Not a big deal. If it didn't, then they may well have blown off the flush.
I'll guess that air got into the system one way or another. Try just giving it a good bleed.
The clutch is self-adjusting. Improper adjustment of the clutch pedal linkage is a different thing. If it was ok before the clutch job, it's ok now.
gravitylover (09-19-2018), jcw99 (09-19-2018)
Old 09-19-2018, 12:20 AM   #14
Ultramaroon
not playing cards
Wow. You had a shit ton of air in there. Well done.
DIY - Stainless Steel Lines - Speed Bleeders - Fluid Bleed/Flush F1point4 DIY (Do-It-Yourself) Guides 99 08-24-2017 06:05 PM
Valve/nipple (bleed?) next to clutch line? BRZyJ Engine, Exhaust, Transmission 2 06-14-2017 12:28 AM
Clutch Fluid Flush? Pls Hlp Keenercarguy Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-19-2016 03:26 AM
swapping brake fluid: taking FOREVER to bleed the air!! snuff58 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 11-02-2015 03:09 PM
How often do i need to change/bleed brake fluid (DoT 5.1) dejxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-15-2015 11:50 AM
