Old 03-28-2014, 07:50 PM   #1
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
Bleed air from radiator/cooling system?
My car has done little over 5000 km (3000 miles aprox), and I noticed I had some gurgling sounds when I take the car into my apt building's parking lot (I usually stop on the downhill ramp to press the garage door opener before driving down the few floors I have to go). Then I noticed I was getting some similar noises under severe braking.
Since I was driving, I parked and popped open the hood and saw that my coolant level (reservoir tank) was on the low side (not under the minimum, but quite close), went to the store and bought some radiator fluid. FYI, Other fluids were ok.
Got home waited a couple of hours and I checked the radiator and the level was ok, and refilled the reservoir tank. Took the car out, drove it a while, went back to the garage and the gurgling noise was smaller.
I thought this was weird since I wasn't seeing any leaks. I haven't done any work on my car that required getting the radiator drained or anything of the sorts. The car is not my Daily driver but I see fluids under the car whenever I take it out.
I have this nagging thought that for some reason I might have air in my cooling system and I probably need to bleed it to make sure all the air is out.
How do you bleed the air in this car's engine? I'd rather get this done at home than take it back to the dealer's mechanic. It takes time from my workday, and I really want to avoid the hassle. But, I'm willing to take the car if you guys think I might have a bigger problem I need to get sorted out.
OnionTou is offline   Reply With Quote
Old 03-28-2014, 08:18 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Just FYI you need to be careful about mixing different types of coolant. For top ups you are often better just using water.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
OnionTou (03-29-2014)
Old 03-28-2014, 08:54 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Lisle Spill-Free™ Funnel on my car:
[ame="http://www.amazon.com/Lisle-24680-Spill-Free-Funnel/dp/B00A6AS6LY"]Amazon.com: Lisle 24680 Spill-Free Funnel: Automotive[/ame]
Seriously, the best thing for a DIY enthusiast since ... well, race ramps.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
BatStig (03-28-2014), Sportsguy83 (03-28-2014)
DIY - Stainless Steel Lines - Speed Bleeders - Fluid Bleed/Flush F1point4 DIY (Do-It-Yourself) Guides 99 08-24-2017 06:05 PM
APR Radiator Cooling Plate Carbon Fiber w/ TRD Intake Subaru BRZ 2013-2014 / Scion FR RallySport Direct Engine, Exhaust, Bolt-Ons 0 02-27-2014 05:25 PM
Mishimoto Radiator & Mishimoto Radiator Hose Kit tlinspired830 Engine, Exhaust, Bolt-Ons 5 01-08-2014 08:44 AM
WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses Sony Engine, Exhaust, Bolt-Ons 0 11-20-2012 11:10 PM
Brake caliper bleed order 96z2 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 10-12-2012 12:54 AM
