#29 | |
Drives: 2017 86 860 Special Edition
Problem with the TOB or snout? AFAIK the snouts on these and other subaru tranny's are prone to fail/get damaged. |
#30 |
Drives: 2023 BRZ
Good question. I am unsure. They will have to do more exploration next week.
Director of Rocky Mountain 86CUP
#31 |
Drives: 14 BSP Edelbrock BRZ
When I just did mine the other day there were witness marks on the input to the diff and what I thought was a matching one on the driveshaft. Turns out what I saw on the driveshaft must have been a sliver of light from my worklight, so I didn't have anything to line back up. I had a droning sound on deccel from 3500 to 2000 rpm. I marked where the shaft was and rotated it. One 90 degree change fixed it.
#32 |
Drives: 2023 BRZ
The shop inspected and replaced the flywheel and clutch today. Here are their somewhat inconclusive notes:
Excessive vibration while driving present. Ran vehicle on lift in 3rd gear at 3k rpms and found increased vibration without load. Verified driveshaft flange markings aligned. No excessive movement in driveshaft. Used stethoscope testing rear differential pinion bushing, carrier bearing and transmission. Found abnormal noise in transmission only. Carrier and pinion smooth. Used borescope camera to inspect clutch and release bearing. Found release bearing doesn't ride smoothly on forks, has an off rotation movement as though pressure plate forks are uneven. To verify drivetrain after trans operation, moved driveshaft flange off original position and test drove. No change in behavior. Based on visual inspection suspect problem with clutch and flywheel internally. Clutch kit removed and found clutch finger discrepancy and missing alignment dowel pin. Clutch and flywheel has abnormal wear on outside only from spinning off centered. Replaced clutch and flywheel and missing dowel. Assembly reinstalled and vibration problem greatly reduced at this time. [shrug] It's not as smooth as OEM, but that's not entirely surprising. I'd say the NVH is reduced by 80% from where it was previously. Good enough for me.
| Does the ACT Streetlight kit need a Verus clutch fork? | Pat | Engine, Exhaust, Transmission | 21 | 02-09-2019 12:31 PM |
| Buzzing/vibrating gear stick | paulca | Issues | Warranty | Recalls / TSB | 49 | 10-12-2017 11:47 AM |
| WTB ACT Streetlight Flywheel or Similar | Cross | Want-To-Buy Requests | 0 | 03-31-2015 06:34 PM |
| Ordered my ACT streetlight clutch kit! Anyone have this? | NickFRS | Engine, Exhaust, Transmission | 17 | 06-17-2013 06:05 PM |
| Buzzing/vibrating speaker fix | CBR600RR | DIY (Do-It-Yourself) Guides | 3 | 05-21-2013 12:11 PM |
