Old 03-13-2019, 11:50 AM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
ACT Streetlight flywheel buzzing/vibrating
I had the ACT Streetlight flywheel and clutch kit installed recently. I chose this kit because I liked the feel of it in two other BRZs I drove. This is my daily driver and I don't want to induce extra NVH. I'm told this kit is designed to be used on the street and should not induce extra NVH, which was my experience when I drove it in the other cars.
I'd rather not pay to have a nearly-new clutch and flywheel removed and replace it with a heavier flywheel and clutch. However, if that's what it takes to eliminate the excessive NVH with this kit, that is what I will do.
I'm hoping the cause of the NVH is not the new lightweight flywheel, but instead something else. Maybe a busted motor mount, bushing, or something else. I have the Whiteline rear subframe and diff bushing inserts in the car, which may not be helping things, either.
What do you guys think? Has anyone else experienced this with this kit? What could be some logical explanation other than the flywheel? I'm hoping to find something else wrong with the car that would explain the NVH, but am struggling to imagine what that would be.
Old 03-13-2019, 11:54 AM   #2
fika84
fika84's Avatar
Be a man. JK. To be fair, when you drove my car you didn't notice the NVH because I HAVE SO MUCH OF IT! Solid everything
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Pat (03-13-2019)
Old 03-13-2019, 12:07 PM   #3
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Are you talking about chatter? Lwfw cause chatter. I have it but you get used to it and get used to what speeds and gear cause it so you can avoid it if you want to.
Sent from my ONEPLUS A6013 using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
The Following User Says Thank You to Strife26 For This Useful Post:
Pat (03-13-2019)
Old 03-13-2019, 12:10 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I had the Xtreme Kit with flywheel SB7-XTSS. Not a street friendly kit IMO. The issues with chatter and hang-ups was too much for DD. If it was a track only car I would have tolerated it.
Took it out and had my stock flywheel put back with a South Bend Stage 2 Daily. Much better for a street car. Now I have a practically new ACT kit in my garage in the box. I think I put 5k miles on it.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Pat (03-13-2019), Rybot (03-13-2019), Strife26 (03-13-2019)
Old 03-13-2019, 12:17 PM   #5
Pat
Pat's Avatar
Drives: 2023 BRZ
My kit is the SB7-HDSS, so a bit different. I think yours has a heavier pedal feel than mine, but they use the same flywheel.
Old 03-13-2019, 12:23 PM   #6
Pat
Pat's Avatar
Drives: 2023 BRZ
I wouldn't call it chatter. Once in a while I hear a tiny bit of chatter at idle but I'm totally fine with that. I'm talking about a buzzing/vibration through the entire car while I drive at nearly any RPM. It is the worst between 2k and 4k RPM, but I can feel it at nearly any RPM. The higher I rev it the less NVH there is. I've tried "driving around it", but it occurs under nearly any conditions, so that's not really a solution.
The Following User Says Thank You to Pat For This Useful Post:
Old 03-13-2019, 12:25 PM   #7
Strife26
Strife26's Avatar
Hmm well I got a lwfw and act clutch with no noise. Maybe something is loose or installed wrong /shrug, not sure.
Pat (03-13-2019)
Old 03-13-2019, 12:31 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I don't think I ever had that. Tons of chatter taking off in first most of the time, but once I was rolling it was actually nice. Felt like a racing clutch, very stiff with great feedback. That is why I say if it was a track car, it would have been ok, but not for a DD my wife often drives. Just too many issues in stop and go.
Drive shaft ok?
Pat (03-13-2019)
Old 03-13-2019, 12:36 PM   #9
Pat
Pat's Avatar
Drives: 2023 BRZ
Sapphireho, do you have any other mods like bushings or bushing inserts?
Old 03-13-2019, 12:39 PM   #10
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Just a couple:
Anti-Lift/Caster Bushing Kit
Front Control Arm Rear Bushings
Heavy Duty Steering Rack Bushings
STI Upgraded Steering Rack Bolts
Rear Subframe Insert bushings
Rear Differential Inserts
Transmission Bushing Insert
Rear Trailing Arm Bushings,
Front Toe Arm Bushings
Inner Lower Rear Control Arm Bushings
roll center adjuster set
And a CF drive shaft.
Old 03-13-2019, 12:44 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
Verrrrry interesting. Thank you for sharing. So, just to be clear, while in motion your ACT kit doesn't add any NVH over OEM, right? Thanks again.
Old 03-13-2019, 01:50 PM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Correct. I did not experience what you are describing.
Old 03-13-2019, 03:21 PM   #13
Grady
Grady's Avatar
I just did the street lightweight flywheel. Also did the rear end bushing stiffeners from Whiteline. You can hear and feel the gears in the rear diff now. I knew it would have more NVH but did not realize that much. After driving a week or so got use to it and not going back.
The Following User Says Thank You to Grady For This Useful Post:
Pat (03-13-2019)
Old 03-13-2019, 03:49 PM   #14
Pat
Pat's Avatar
Drives: 2023 BRZ
I am not feeling the gears. This is something completely different. I know what you're referring to, as I heard that when I changed the bushings too. The buzzing that I am referring to is completely different.
Does the ACT Streetlight kit need a Verus clutch fork? Pat Engine, Exhaust, Transmission 21 02-09-2019 12:31 PM
Buzzing/vibrating gear stick paulca Issues | Warranty | Recalls / TSB 49 10-12-2017 11:47 AM
WTB ACT Streetlight Flywheel or Similar Cross Want-To-Buy Requests 0 03-31-2015 06:34 PM
Ordered my ACT streetlight clutch kit! Anyone have this? NickFRS Engine, Exhaust, Transmission 17 06-17-2013 06:05 PM
Buzzing/vibrating speaker fix CBR600RR DIY (Do-It-Yourself) Guides 3 05-21-2013 12:11 PM
