Old 02-13-2019, 10:32 PM   #1
ckmninja
Drives: 2016 Asphalt FRS MT
Stripped Studs
So I was installing my coils and during the install, I found almost 8 stripped and 2 broken studs. I got my wheels and new sr48 lugs mounted about 6 months ago from a pretty reputable shop. I know the oem studs aren't the best but never had this issue on my other cars, would it be due to bad install and how to prevent it in the future?
Size:  800.1 KBName:  IMG_1620.jpg
ckmninja is offline   Reply With Quote
Old 02-13-2019, 10:57 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's a combination of shitty lugs, weak studs, and over torqued. To pin point the actual cause, eh? Who knows. Could be one or could be all three.
Just get some nice apr wheel studs and move on.
The Following 3 Users Say Thank You to Mr.ac For This Useful Post:
humfrz (02-14-2019), Leonardo (02-13-2019), TofuJoe (02-14-2019)
Old 02-14-2019, 02:40 AM   #3
AngelGT86Racer
AngelGT86Racer's Avatar
Drives: 2013 FR-S, 2007 Acura TL 5AT
The stock studs are pretty weak in my opinion. I've seen these shear when torquing to OEM settings ~80lb-ft.
The first thing I did when I got my FRS was replace all of my studs.
ARP 100-7727 seem to be the gold standard. They will run you about $120 for the car and shouldn't ever have an issue.
If you want to save some money, I recommend Dorman 610-566 for $50. They're grade 10.9 and seem to have sufficient tensile strength. I've ran them for years on different cars and never had an issue when using proper torque.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build
YouTube: Angel Christov
AngelGT86Racer is offline   Reply With Quote
Old 02-14-2019, 03:12 AM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I've stripped countless studs. I have a set of APR and just haven't yet installed them. In the meantime, I undertorque the wheels and check them periodically.
Old 02-14-2019, 03:18 AM   #5
86MLR
86MLR's Avatar
OEM studs, OEM lugs
I've had my wheels on and off dozens of times without issue.
I always use a torque wrench to spec, I also add a small touch of grease to the lug face and stud thread.
Been doing that for near on 40 years without ever stripping treads or snapping lugs, road, track, drags and dirt, never a issue.
Old 02-14-2019, 08:20 AM   #6
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by AngelGT86Racer View Post
The stock studs are pretty weak in my opinion. I've seen these sheer when torquing to OEM settings ~80lb-ft.
im installing the 100-7728 right now. the oem studs suck. i yielded one nad broke another taking my summers tires off.
Old 02-14-2019, 09:56 AM   #7
cjd
cjd's Avatar
Drives: 2017 BRZ
That looks like it was cross threaded and forced, probably just impacted on.
Averaging 40+ wheel swaps a season and I've never had issues... While the stock stuff is clearly not the best, it takes work for it to be as bad as this.
89lb/ft. 80 is too low and could cause issues. Also maybe an accidental typo but just in case this is randomly referenced by someone...
The Following User Says Thank You to cjd For This Useful Post:
wparsons (02-14-2019)
Old 02-14-2019, 10:35 AM   #8
Joon525
Joon525's Avatar
Drives: 2016 BRZ
I've watched shops do this and cringed every time. You hand thread it first, then use the impact.
OP: You're going to have a hard time proving anything at this point, but use the opportunity to get APR studs and put them in yourself or if you have to, find a more reputable shop to help you.
Joon525 is offline   Reply With Quote
Old 02-14-2019, 12:43 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Two real issues:
1) the shop probably didn't clean the threads + hand thread the lug nuts to prevent contamination/cross threading
2) SR48 are open ended lug nuts, you need to make sure the threads are clean before you install them
Minor dirt or contamination on the threads of an open ended lug nut can lead to premature failure of the stud. A simple wipe of the threads with a towel usually is good enough, but most people (and shops) don't do this at all when installing new open-ended lug nuts.
The other part is that with cheaper lug nuts like SR48, the lugs are usually coated/treated in a dip at the end of manufacturing. So there may have been loose pieces of coating that flaked off as you installed, making your problem worse.
Old 02-14-2019, 02:22 PM   #10
AngelGT86Racer
Sorry, meant to write 85. I torque mine to 85. I didn't know the spec was 89.
I'll set my torque wrench to 89 from now on.
Thread Restorer Kit to repair lug studs (sticking/stripped/misthreaded lug nuts) GrantedTaken Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-16-2018 12:19 PM
Bought winter tires with studs (live in hilly area). Now I want to remove the studs.. redwing634 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-18-2016 09:57 PM
At what point do we need to upgrade head studs and main studs? Amir Ghadiri Forced Induction 5 03-03-2015 12:13 PM
Wheel bolt stripped 2pointSLOW86 Issues | Warranty | Recalls / TSB 23 10-13-2014 03:29 AM
Have you stripped some weight off your FRS? gt8613 Scion FR-S / Toyota 86 GT86 General Forum 39 08-20-2013 03:11 PM
