At what point do we need to upgrade head studs and main studs?
Could anybody with first hand experience chime in on how much power the factory head studs and main studs can handle?
I'm currently building my motor and trying to determine if it's worth doing for the power goals I've got in mind. Thanks for your input!!
#2 | |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
That said, you should spend the extra money and upgrade considering it's pretty cheap for ARP fasteners.
| The Following User Says Thank You to slicktop For This Useful Post: | Amir Ghadiri (03-03-2015) |
Drives: 2014 SWP BRZ, MT
From building EJ motors, the head studs are more dependent on the boost you plan to run to prevent head lift, and the case bolts I'm not sure what the failure point was. The head studs are cheap enough to run just for insurance. I did read about the case bolts messing with the main journal oil clearances though because of the different torque specs. What's your power target?
The answer is racecar. Always.
| The Following User Says Thank You to zkv476 For This Useful Post: | Amir Ghadiri (03-03-2015) |
#4 | |
I'll be running 20psi on pump and possibly 27-28 on e85. I'm assuming power will be at approx 425-450 and 550-575 wheel, but I don't necessarily have a hp goal I need to meet. I was thinking I'd just upgrade the head studs and keep factory case studs, and it sounds like that may be a good plan?
You definitely want head studs for that level of boost. But yes that's a good plan. Unless you are building a car for time attack or majority track duty and harsh abuse you don't really need the case bolts. They require a decent bit of work alongside them, since they oval the main bearings if you just put them in.
#6 | |
| WTB OEM Wheel Studs | Anthony | Want-To-Buy Requests | 8 | 08-27-2014 03:22 PM |
| WTB: tires and studs | jammz | Wheels and Tires | 0 | 02-24-2014 10:29 PM |
| summit point main 9-14 -9-15 | subaruferrucci | Tracking / Autocross / HPDE / Drifting | 15 | 09-17-2013 05:48 AM |
| SUMMIT POINT MAIN, still NA and 2650 weight. | Racecomp Engineering | Tracking / Autocross / HPDE / Drifting | 3 | 08-19-2013 01:12 PM |
| Extened Studs? | BlaineWasHere | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-29-2013 11:29 AM |
