Old 12-23-2018, 06:53 PM   #1
1quickchic
Drives: 2013 Panda ft86/FRS
Car won't crank without the oft plugged in
Just as the title reads, cr went down to be built/turboed, now that it's back together it isn't want to crank(rotate engine) without the oft plugged into the the port,
Flashed the ecm to the new map and back, and then again it does the same thing, I'm going to go over it all again but this one has got me
1quickchic is offline   Reply With Quote
Old 12-23-2018, 08:23 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
This might seem like a silly question but are you sure it cranks with the oft plugged into the obd port?
Old 12-24-2018, 12:37 AM   #3
steve99
Drives: FT86
That makes no sense.
The oft or any flash device transfers tune to ecu then it takes no further part in engine operation.
If your turbo its likely that the tune you flashed does not match the MAP sensor installed or the injectors installed.
Old 12-24-2018, 01:11 AM   #4
1quickchic
I got it sorted, it was something very dumb
The Following User Says Thank You to 1quickchic For This Useful Post:
bcj (12-25-2018)
Old 12-24-2018, 01:19 AM   #5
Brink
Drives: 2017 BRZ
But you're not gonna tell us what dumb little thing it was?
Brink is offline   Reply With Quote
Old 12-24-2018, 10:47 AM   #6
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
does a female EVER tell you what the problem is straight up? haha.
we gotta SOLVE IT OURSELVES MAN.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
The Following User Says Thank You to Soloside For This Useful Post:
tomm.brz (12-24-2018)
Old 12-24-2018, 10:57 AM   #7
bcj (12-25-2018), Ultramaroon (12-24-2018)
Old 12-28-2018, 02:38 AM   #8
1quickchic
it was a ground
bcj (12-28-2018)
OFT Keep plugged in without killing battery? Axion Software Tuning 19 06-06-2020 11:30 AM
connectors not plugged in?? trexx0411 Scion FR-S / Toyota 86 GT86 General Forum 8 08-03-2015 09:00 AM
Found A Connector Not Plugged In bruizerrob Scion FR-S / Toyota 86 GT86 General Forum 14 08-03-2015 07:55 AM
Stock FRS radio harness there but not plugged in? Roadstercycle Electronics | Audio | NAV | Infotainment 1 04-20-2014 05:33 AM
Are my accessory jacks plugged in? dale.m Electronics | Audio | NAV | Infotainment 3 10-09-2012 01:14 AM
