Old 12-03-2018, 12:33 AM   #29
Legend@wheels
nenber
dammit, humfrz.
You are actually shifting too slowly. Inexperienced careful owners often mistake shifting gently with shifting slowly. I will do my best to explain/support my argument. This will either cure the issue, or it will help us troubleshoot. Then humfrz will bookmark this thread and refer to it future owners who want to better understand their transmissions.
One good thing about shifting carefully is the reward felt from a well-executed shift. It also increases the number of miles - or more precisely, the number of shifts into each gear - it will take for your transmission to break in. Does it improve the overall service life of the transmission? I don't really know. It can't hurt.
__________________________
The syncros are carefully sized for this application. They don't give you any extra juice to make up for sloppy shifts. The gearbox is also more sensitive to viscous drag than any other I can recall. Opinions vary about how to manage this. I've read about how it likes to be man-handled, or how it only works well when you shift at a higher rpm, blah blah blah... I say that if you have a realistic idea of what's going on in there, you can tailor your shifting style according to operating conditions and potentially extend the vehicle's service life overall. For instance, with what I've learned about the oiling system, I shudder at the idea of running this engine cold above 2500 rpm. The whole idea of running it up to 4K just to get into second is ludicrous.
Do I have your attention?
hi
i shift too slowly/@early rpm?even if i do its still not the problem anyway..
cuz when i shift fast/@high rpm its still acts the same so its not that.
Also that Pre grinding feel happens like 1/4 times of shifting from 2 to 3 and and from 1 to 2 about 1/6 times -no matter what rpm i am and no matter how gentle/harsh i shift .
im driving manual cars for like 10years im very familiar with those boxes.even though
ill try to put more attention to it next time i drive the subie and to shift in less gentle motion .
Legend@wheels is offline   Reply With Quote
The Following User Says Thank You to Legend@wheels For This Useful Post:
humfrz (12-03-2018)
Old 12-03-2018, 12:42 AM   #30
churchx
churchx's Avatar
Drives: 2014 GT86
I guess he was refering not rpms at which to shift, but rather shifting motion, how you move lever.
Legend@wheels (12-03-2018), Ultramaroon (12-03-2018)
Old 12-03-2018, 12:48 AM   #31
You know the drill. Why me?
Because I just wanted the OP to hear it from the expert. Anything I may say, the OP may think that Bubba told that to me -
humfrz is online now   Reply With Quote
The Following 3 Users Say Thank You to humfrz For This Useful Post:
churchx (12-03-2018), Legend@wheels (12-03-2018), Ultramaroon (12-03-2018)
Old 12-03-2018, 12:49 AM   #32
Legend@wheels
nenber
but maybe the bubba told him too?@ that you didnt think huh? lol
The Following 2 Users Say Thank You to Legend@wheels For This Useful Post:
humfrz (12-03-2018), Ultramaroon (12-03-2018)
Old 12-03-2018, 12:56 AM   #33
Well, not to worry, @Ultramaroon never listens to Bubba - why not.
Old 12-03-2018, 12:57 AM   #34
Legend@wheels
nenber
oh in that case im calm.
humfrz (12-03-2018)
Old 12-03-2018, 01:08 AM   #35
Seriously, here is something to check.
Check the fluid level in the clutch reservoir and top off if necessary.
Another thing you might try is to bleed the clutch hydraulic system. You may have gotten some air in the system, which would not allow the slave cylinder to be pushed in as far as you may think.
Old 12-03-2018, 01:20 AM   #36
hi
It is possible that the balk rings are worn but unlikely that they just happen to be in second and third only.
it's not about harshly/gently. It's about not pausing in neutral. This only pertains to upshifting. Downshifting is a different story.
humfrz (12-03-2018), Legend@wheels (12-03-2018)
Old 12-03-2018, 01:48 AM   #37
Legend@wheels
nenber
Done all of that
Sent from my SM-G960F using Tapatalk
humfrz (12-03-2018)
Old 12-03-2018, 03:43 PM   #38
Legend@wheels
nenber
No matter how i shift its still crap.
Double clutching eliminating it by 90% but still..
Oh well ill let it to get abit worse so it will be more noticeable and than will take it to the dealer to replace with a new transmission.
Luckily i got enough time for the warranty.
Thank you mates.
humfrz (12-04-2018)
Old 12-03-2018, 08:28 PM   #39
Thank you mates.
There have been some bum builds. It's not out of the realm of possibility. Good luck. Keep us up to date.
humfrz (12-04-2018), Legend@wheels (12-03-2018)
adjusting trailing arm puma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-11-2025 04:04 AM
Adjusting headlights hansthegerman Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-09-2017 10:39 PM
Adjusting the bass Stewie Electronics | Audio | NAV | Infotainment 2 04-13-2015 11:22 AM
Adjusting the base on coilovers Turdinator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-11-2014 08:56 PM
Adjusting to FR-S Clutch. Mandy Scion FR-S / Toyota 86 GT86 General Forum 19 02-09-2013 12:24 AM
