Old 08-19-2012, 08:19 PM   #1
hansthegerman
Drives: Scion FRS
Adjusting headlights
Idk if this is the right place for this, but how do you adjust the up down on the headlight of the FRS. I just installed hids and would like to aim them down a bit. Ive tried searching and couldnt find anything, checked the manual aswell.
hansthegerman is offline   Reply With Quote
Old 08-19-2012, 08:35 PM   #2
frs
Drives: frs
theres a knob you can turn with 10mm to adjust beside the light bulb socket
frs is offline   Reply With Quote
Old 08-19-2012, 08:39 PM   #3
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
http://www.ft86club.com/forums/showp...91&postcount=2
Jidonsu is offline   Reply With Quote
Old 08-20-2012, 09:49 AM   #4
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Originally Posted by Jidonsu View Post
This just adjusts the height of the light not the cutoff, like mashing the squirrel finders does, right?
jadewbj is offline   Reply With Quote
Old 08-20-2012, 10:07 AM   #5
Jidonsu
The cutoff goes up or down as you aim the lights up or down.
Old 08-20-2012, 04:35 PM   #6
hansthegerman
Drives: Scion FRS
Wow, can't believe I couldn't find that. Thanks.
Old 09-09-2017, 02:43 PM   #7
radroach
Drives: car
Since Photobucket stopped working, can we get a refreshed tututorial? I need to adjust my headlights horizontally and vertically. . . And what I'm seeing is not consistent with what I'm reading in that linked post.
Old 09-09-2017, 06:25 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
LIGHTING (EXT): HEADLIGHT ASSEMBLY (for HID Headlight): ADJUSTMENT
https://demos.starbase7.net/t3Portal...011MI099X.html
Old 09-09-2017, 06:36 PM   #9
radroach
Drives: car
@Ultramaroon you are a shining star sir
Old 09-09-2017, 06:55 PM   #10
Ultramaroon
not playing cards
Aw, shucks. *kicks dust*
Old 09-09-2017, 07:56 PM   #11
radroach
Drives: car
So this handles up and down. But how do you horizontally adjust it?
blog: I had a fender bender a while ago and got new headlights among other parts, but they didn't replace the aluminum beam that runs along the top. I suspect it might be ever slightly warped that it might cause these headlights to be misaligned. It's not super bad, but its noticible especially since the stock headlight angles were so perfectly flat from the factory.
If that bar is warped, is there any other way I could adjust the headlight direction? Or should I look into getting a new beam that aligns all these parts? Maybe get a mallet and whack it back into shape lol?
Old 09-09-2017, 08:10 PM   #12
Ultramaroon
not playing cards
Hmmm.. I'll have a close look at mine as soon as Mrs. Ultra gets home from the fabric store in Portland. We traded so I could look for a suspension related pop in her Camry.
I have the standard halogens but there might be enough similarity.
Old 09-09-2017, 10:04 PM   #13
NRXRaptor
The only reason I can think of for horizontally misaligned lights is if either the bulbs or the entire housings aren't screwed in/secured properly. I put in aftermarket foglights and they weren't lined up so I fiddled with the screws and fixed it. It turned out that the stock hardware wasn't quite behaving with the new lights and that fixed it. I also put in aftermarket headlights and after fixing the wiring nightmare (something was causing a short circuit) I only had to fiddle with the headlight leveling screw to fix them
NRXRaptor is offline   Reply With Quote
Old 09-09-2017, 10:39 PM   #14
Ultramaroon
not playing cards
I don't see a horizontal adjustment. There may be some intentional slop in the mount points but not much. I think it depends mostly on the alignment/integrity of the radiator support. ...front clip, whatever it's called.
https://demos.starbase7.net/t3Portal...00000Y5XM.html
Scion FR-S: Adjusting the headunit / NAV "hidden menu" settings EsoBOFH DIY (Do-It-Yourself) Guides 17 04-30-2014 10:11 PM
Adjusting The Swing Length of the Door 7thgear Cosmetic Modification (Interior/Exterior/Lighting) 2 11-13-2013 06:40 PM
DRL & Headlights Heero Cosmetic Modification (Interior/Exterior/Lighting) 23 09-01-2013 12:56 PM
Adjusting the Rearview Mirror pinoyplaya BRZ First-Gen (2012+) — General Topics 2 08-24-2012 10:45 AM
Headlights too dim Franisco Other Vehicles & General Automotive Discussions 10 05-15-2012 04:11 PM
