Old 12-01-2018, 10:53 AM   #1
Legend@wheels
nenber
Gear adjusting?
Hi
Is there such a thing 'gear adjustment' in our cars?
From 2 to 3 sometimes it feels like pre grinding feel(like the synchro is on its way out)maybe it is just adjustment job or trans is about to be replaced.
2 friends drove my car and confirmed their brz's dont feels that way.
Sent from my SM-G960F using Tapatalk
Legend@wheels is offline   Reply With Quote
Old 12-01-2018, 12:13 PM   #2
humfrz
Originally Posted by Legend@wheels View Post
Hi
I'll ask our best transmission guy, @Ultramaroon to comment -
How many miles on your car?
Do you have a short shifter?
Have you checked the transmission fluid level?
humfrz
Legend@wheels (12-01-2018)
Old 12-01-2018, 12:19 PM   #3
Legend@wheels
nenber
humfrz
22k miles 15'.
No.
Oil changed recently with 300 motul(and feel the same)
The Following User Says Thank You to Legend@wheels For This Useful Post:
humfrz (12-01-2018)
Old 12-01-2018, 01:13 PM   #4
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
How quickly are you trying to change gears? Is the transmission fully warmed up? I also have Motul 300 in my transmission and if I try to quickly change gears while the transmission is still cold it will feel like there is some resistance going into the next gear, sort of like it is about to grind. I've found that it's best to shift a little more "gently" until everything is fully 100% warmed up.
Have you adjusted the clutch pedal at all? If the pedal has been lowered too much it may not be fully disengaging the clutch, making it hard to jam it into gear.
Face_Plant is offline   Reply With Quote
The Following 2 Users Say Thank You to Face_Plant For This Useful Post:
humfrz (12-01-2018), Legend@wheels (12-02-2018)
Old 12-01-2018, 01:24 PM   #5
Legend@wheels
nenber
Slow like granny.
And well warmed -all of those basic i always do.
I suspect the clutch require an adjustment .
It feels like the clutch isnt fully enggaged.
P.s i didnt play with the clutch bite level.
Old 12-01-2018, 01:49 PM   #6
humfrz
If the car is still under warranty, you may consider taking it back to the dealer and see what they have to say -
humfrz
Old 12-01-2018, 01:58 PM   #7
Legend@wheels
nenber
The dealer is bunch of morons.
They might go for the easy and quick solution-trans replacement.
I assume they dont know the idea of clutch/gb adjustment.
Old 12-01-2018, 02:26 PM   #8
humfrz
Well, that's too bad.
You may consider adjusting the clutch yourself.
http://www.ft86club.com/forums/showt...tch+adjustment
humfrz
Old 12-01-2018, 02:28 PM   #9
Legend@wheels
nenber
humfrz
This one is just for the bite point i think..
Saw that one.
My clutch is at the heighest bite point ..
I think there is another adjusting method ,which is more 'mechanical'
humfrz (12-01-2018)
Old 12-01-2018, 02:46 PM   #10
Legend@wheels
nenber
Came across to that one:
[ame]https://m.youtube.com/watch?v=vYJxQyjIhUw[/ame]
Might be the solution ? Possibly
Old 12-02-2018, 01:42 AM   #11
Legend@wheels
nenber
ive just tried the 'drag clutch testing' and my clutch isnt dragging,should ill adjust the clutch anyway?
got to rev limite 1st gear clutch pressed and the car didnt move not even a single mm .
Old 12-02-2018, 03:03 AM   #12
humfrz
Well, I'm just not sure about this clutch. Back in the day, we would adjust the clutch travel so that it would disengage completely when the pedal was pushed all the way to the floor and at the same setting have at least one inch of free play when the clutch pedal was released completely.
How about the other gears, do they engage smoothly?
humfrz
Old 12-02-2018, 03:13 AM   #13
Legend@wheels
nenber
humfrz
4 5 6 smooth but i barely use en either..
2 and 3 are the trouble maker
Old 12-02-2018, 03:27 AM   #14
humfrz
I'm going to hail ol @Ultramaroon ,again, to see if he has any ideas.
humfrz
adjusting trailing arm puma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-11-2025 04:04 AM
Adjusting headlights hansthegerman Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-09-2017 10:39 PM
Adjusting the bass Stewie Electronics | Audio | NAV | Infotainment 2 04-13-2015 11:22 AM
Adjusting the base on coilovers Turdinator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-11-2014 08:56 PM
Adjusting to FR-S Clutch. Mandy Scion FR-S / Toyota 86 GT86 General Forum 19 02-09-2013 12:24 AM
