Old 11-24-2018, 01:18 PM   #29
churchx
churchx's Avatar
Drives: 2014 GT86
cjd: if you want to dvelve as deep in alignment precision .. remember that it changes depending on load. Was your alignment done with you sitting in car or not?
Old 11-24-2018, 01:25 PM   #30
jamal
jamal's Avatar
Drives: Legacy GT
And how level is the car, how good are the slip plates, how accurately can you determine the centerline of the chassis, how does that relate to the position of the suspension and wheels, etc.
1mm at the rim is about 0.1 degrees. Which I suppose is a pretty good reason to measure in mm instead of fractions of an inch.
jamal is offline   Reply With Quote
Old 11-24-2018, 01:30 PM   #31
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by JIM THEO View Post
And here I am worrying about some minutes while people can't even sort out how many mm of toe they even have!
Hey, at least I know that radians and minutes and degrees all exist. I'm mostly just too lazy to do the math most days.
Me? no. An approximate representation, give or take? Yes. Gas in tank too, I know... I'm not as worried about the level of precision, just found it vaguely funny.
I got that at the wheel, not the rim. Rounding differences probably...
Old 11-24-2018, 03:20 PM   #32
JIM THEO
Drives: BRZ 2018
I don't convert often degrees to minutes cause I have my own alignment specifications based in my experience and my tire pyrometer not the forum, I just tried to help and according to ZDan's calculations it was 8.6' instead of ~7' I wrote, so wrong that worth long conversation, keep your ironic comments I keep my fault, we are so different...
JIM THEO is offline   Reply With Quote
Alignment question. ohnoitsthefuzz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-09-2015 07:33 AM
Alignment question? cjsporl1996 Tracking / Autocross / HPDE / Drifting 13 05-12-2014 04:00 PM
brz alignment question Shenks BRZ First-Gen (2012+) — General Topics 2 02-12-2014 09:23 PM
alignment question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-15-2013 12:52 PM
Alignment question retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-11-2013 10:44 PM
