Old 11-19-2018, 12:38 AM   #71
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
My question is, i wonder if this dual snorkel intake will provide higher or just as same power gains as the greddy itb's. This is including a bigger throttle body. If it provides the same gains at least, looking at cost, the revolution intake is very much worth it.
Dr. BRZ is offline   Reply With Quote
Old 11-19-2018, 09:23 AM   #72
RayRay88
Drives: 2017 86 860 Special Edition
They're not even in the same league in terms of power adders...
RayRay88 is offline   Reply With Quote
Old 11-19-2018, 12:30 PM   #73
Dr. BRZ
Dr. BRZ's Avatar
From what ive read this setup revolution intake and the guy in the greddy itb post are pulling the same numbers on 91.
$1500 vs $3000
Old 11-19-2018, 12:56 PM   #74
RayRay88
$1500 vs $3000
The ITB's will net you much more mid range/overall torque, not to mention throttle response will be drastically sharper with the ITB's.
Please don't take offense to this, but if you're cross shopping the two then the ITB's are not for you.
Old 11-19-2018, 01:30 PM   #75
Dr. BRZ
Dr. BRZ's Avatar
The only difference between the 2 i see, is the itb's gave just a lil more torque than the dual ram intake. The throttle response has increased in both, claimed from the owners and gave good mid range too. Until i see counterspace garage pull some big numbers and not similar numbers, people are going to lean towards the revolution intake, NA style.
Read this guy's post, he describes the same results from the guy with the itb.
Old 11-19-2018, 01:36 PM   #76
Dr. BRZ
Dr. BRZ's Avatar
Keep in mind, @Mockinbird87 dyno is with the stock throttle body and not the suggested bigger throttle body, which tells the revolution intake could pull more numbers.
Old 11-19-2018, 01:59 PM   #77
RayRay88
Throttle response with ITB's will still be significantly better than any intake can provide.
The last dyno from an ITB'd twin showed close to 180 wtq. I know its not a fair comparison but it's substantial enough. He also was reporting near 60 whp increase over stock with ITB's and a nameless header.
It's hard to say without a back to back dyno comparison but it's safe to say you won't get the same type of dyno curves with just an intake and throttle body.
Not to mention it's not $1500 vs $3000
ITB's require a ton of work to get them to sync/run with the engine. Then comes the hours of dyno tuning to get the most out of them.
You can easily double the cost of the ITB's.
Like I said if you're cross shopping an intake and ITB's, the ITB's are not for you.
Old 11-19-2018, 06:37 PM   #78
Hawk77FT
Drives: GTS 86
Why not both? I am planning to get the SARD ITB at some point and couple it with my intake
Hawk77FT is offline   Reply With Quote
Old 11-19-2018, 08:14 PM   #79
Dr. BRZ
Dr. BRZ's Avatar
I thought about that too but too much $$$$$.
I'm all NA but i dont want to spend that much $$$$
Old 11-19-2018, 08:53 PM   #80
Lantanafrs2
Drives: 2013 frs red
I don't think we've seen an accurate dyno graph yet for itbs in terms of delta over stock.
Lantanafrs2 is offline   Reply With Quote
Old 11-19-2018, 10:10 PM   #81
RayRay88
NA Is probably the most expensive way to make power.
Have you thought about a positive displacement supercharger? Might be what you’re really after.
Old 11-19-2018, 11:59 PM   #82
Dr. BRZ
Dr. BRZ's Avatar
I have a nitrous kit sitting in the garage, waiting for summer to install.
Old 11-20-2018, 09:49 PM   #83
Lantanafrs2
I wouldn't even consider itbs til we get results from delicious
Old 11-20-2018, 10:48 PM   #84
Hawk77FT
Drives: GTS 86
On my list I have ITB, displacement kit, Supercharger. That should give me some good reliable power
Gruppe-S Unequal length header UEL - good power, excellent sound/quality - must SEE! Gruppe-s Engine, Exhaust, Bolt-Ons 680 12-26-2022 10:46 PM
Centering caps for the TC105N from Gruppe-s cjd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 11-09-2021 04:57 AM
revolution garage rear subframe solid bushings review mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-01-2015 11:09 AM
Gruppe-S tahdizzle User/Vendor/Sponsor Reviews, Feedback, Comments 13 05-06-2015 12:30 PM
Revolution x GruppeM Intake TwinRz Engine, Exhaust, Transmission 15 07-31-2014 08:34 PM
