Old 09-05-2015, 05:52 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
Gruppe M / Revolution garage intake
I am speechless that this intake is in my hands only true ram air design for frs/brz platform. Crappy cellphone photos do not do justice for this piece.. Can't wait till I install it! I will be doing a before/after dyno. This intake is more about keeping the horsepower under high stress conditions (according to some Japanese reviews, every 1 degrees Celsius you lose 0.7hp), but just want to see if it actually makes any difference. stay tuned.
mokinbird87 is offline   Reply With Quote
The Following User Says Thank You to mokinbird87 For This Useful Post:
Kayshart (09-07-2015)
Old 09-05-2015, 07:33 PM   #2
OkieSnuffBox
Drives: '23 BRZ Limited
So I guess you haven't seen the Greddy scoop?
http://counterspacegarage.com/greddy...-frs-gt86.html
Old 09-06-2015, 09:03 AM   #3
zooki
Drives: waiting on a 2021...
Do you have any pictures of the inside of the air box? Does the area where the MAF mounts have a radiused outlet? Velocity stack? thanks.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 09-06-2015, 02:25 PM   #4
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
so much want! but i cant reason myself spending over $1000 for this piece! so.... i only spent $200 and got the greddy snorkel! and let me tell you, i can feel the difference! $200 well spent!
Dr. BRZ is offline   Reply With Quote
Old 09-06-2015, 06:21 PM   #5
mokinbird87
BOXER FR
here ya go.
Old 09-06-2015, 06:34 PM   #6
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Ballin!
In for installed photos!
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
mokinbird87 (09-06-2015)
Old 09-06-2015, 11:12 PM   #7
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
In for dynooo
jaorocks1 is offline   Reply With Quote
Old 09-07-2015, 11:41 AM   #8
sw20kosh
Drives: 2013 Black FR-S
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
raven1231 (09-07-2015), RehabJeff86 (09-14-2015)
Old 09-07-2015, 12:19 PM   #9
nelsmar
Are you doing tuned before and after or untuned on both? I've been wondering about this intake. It's about time someone got one!
I would love to see a log of the maf voltage before and after. I'm curious how much different it is as the oem is right after a bend.
My flickr - Canibeat
Local magazine scout
Old 09-07-2015, 12:22 PM   #10
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
No. That Greddy scoop retains the original airbox and thus the 90 degree bend downstream. Look carefully and observe the difference.
He said true ram style and he was correct. Straight shot from airbox to throttle body.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Old 09-07-2015, 03:10 PM   #11
zooki
They both(and even the stock snorkel) take air from the high pressure area directly in front of the radiator. If you were to take a pressure reading from directly in front of the MAF you probably wouldn't see any difference between the three.
Old 09-07-2015, 03:34 PM   #12
Teseo
Drives: frs
Pictures after installation
Old 09-07-2015, 07:11 PM   #13
Spartarus
...Just add nauseum
Spartarus's Avatar
Yes. They do. I wasn't even addressing that. But the others have multiple 90 degree bends. The thing that distinguishes this intake is the geometry down stream of the filter, not the place where it picks up air. This one is a straight shot from filter to throttle body.
By the way you would absolutely see a pressure drop equal to at least the filter differential pressure in any intake. And then after that every bend in the pipe further reduces airflow.
Velocity matters as much as pressure when determining flow.
I'm not saying this means automatic power gains as there are more factors that go into it (resonance for instance) but this has the potential to be a better design for several reasons.
-Spartarus
Old 09-07-2015, 08:39 PM   #14
zooki
I was actually talking about the difference in pressure between the three measured at the same spot. I realize the air filter will cause a pressure drop. I seem to remember reading somewhere that Coswioth determined the stock intake tract would support 300 HP with a drop-in filter, but I can't find it now.
I also wonder about putting the air box behind the radiator where it would have warm air constantly blowing across it. I realize CF is a good insulator, but I wonder if it's enough to negate this? Oh well, time(and the dyno) will tell, I suppose.
Gruppe-S Unequal length header UEL - good power, excellent sound/quality - must SEE! Gruppe-s Engine, Exhaust, Bolt-Ons 680 12-26-2022 09:46 PM
Centering caps for the TC105N from Gruppe-s cjd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 11-09-2021 03:57 AM
revolution garage rear subframe solid bushings review mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-01-2015 10:09 AM
Gruppe-S tahdizzle User/Vendor/Sponsor Reviews, Feedback, Comments 13 05-06-2015 11:30 AM
Revolution x GruppeM Intake TwinRz Engine, Exhaust, Transmission 15 07-31-2014 07:34 PM
