Old 07-23-2015, 09:56 PM   #1
cjd
cjd's Avatar
Drives: 2017 BRZ
Centering caps for the TC105N from Gruppe-s
Though these have their origins elsewhere, the logistics of organizing a run of these custom parts seems a bit more than most are interested in tackling. I had been considering it but balked at the cost and probable stress of such an endeavor. Fortunately for us, @Gruppe-s has decided to consider offering these. Already a great place to get the WedsSport TC105N, this makes it just a little better.
To start with, these are dual function, providing both a cap for the hub, and a centering ring for the wheel. The center caps WedsSport offers do not provide the centering function, and are actually incompatible with centering rings. While not required for these (they're lug-centric if you're patient and careful,) if you're like me and sometimes change wheels in a bit of a hurry, ... well, that's a somewhat less than ideal way to go.
Speaking of in a hurry... I've got a road trip tomorrow, my power washer is on loan, and I had my race tires on the car, and needed to swap them out. So the pics will have slightly less than pristine clean car pictures. Fear not, I'll add more later.
For starters, the machining is clean - no frills, very light toolmarks (as opposed to a cleaned or polished finish) - they're shipped in individual boxes, wrapped in a plastic bag within the box. Mine had signs of handling on the surface, but nothing significant (and nothing close to what use will do.) I believe these are part of a test run, so the handling is to be expected in this case.
Fit and finish are clean - a very slight bit of play on the hub, and none I could easily detect in the wheel. The (plastic) centering rings I have are similar. I found that I could get these stuck if I didn't place them into the hub center straight; a bit off kilter and they'd grab. So tolerances are very close, and that's good.
They sit slightly proud of the hub center on the face side, with the easing on the wheel and the cap seeming to meet cleanly - if they were flush I think they might look slightly odd, but this looks quite good.
The color is subtle, and will probably go with any color they offer - a slight bronze tint. It goes well with the somewhat common Titan Silver, as well as the Dark Grey Metallic quite nicely. It would be fun to have these in blue to go with my numbers, but I won't complain. Maybe some day. And for most days, a slightly lower profile is probably to my benefit here in the city.
Installation was straight-forward. Since they don't hold in the wheel, I found it slightly easier to put the cap on the hub, then slide the wheel straight on. I could have used a little painters tape across the face to hold it into the wheel as well. If they're not fully seated in the wheel when you place it over the lugs, be careful to seat the wheel perfectly straight or, as noted, the cap may stick in the hub center.
For those counting, I weighed these in at 61.8g (2.18oz) - for a little extra protection against the elements, I won't complain one bit - especially on the rear axle. Size is 65mm for the wheel hub and a 56.1mm interior bore for the hub.
For now, I'll leave you with a picture of the very dirty car (you can't see it here, but my numbers are clearly readable in the dust from last Sunday,) ready for a road-trip tomorrow. 17x8 with 225/45/17 PSS. The DGM are 17x9 with 255/40/17 RE71-R. More pics later - if I don't do an actual shoot here or there, I'll at least get some shots at the next event I race.
Before these, with lovely pink centering rings...
The new style with custom paint
Last edited by cjd; 07-08-2016 at 07:48 PM. Reason: updating with some dimensions, more pics
Old 07-23-2015, 09:59 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
reserved in case I just take that many pictures...
Old 07-23-2015, 10:07 PM   #3
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
Looks good , this would solve RPF1 problem of ugly and expensive center caps, and need for hubcentric rings. Are there measurements for these? I'd consider purchasing to use on my RPF1s.
blue cat is offline   Reply With Quote
Old 07-23-2015, 10:17 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
65mm, too small for the RPF1. Maybe if you ask nice they'll expand the line (I imagine first they have to prove worthwhile in this size...)
Old 07-24-2015, 01:20 AM   #5
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Link to purchase?
Kostamojen is offline   Reply With Quote
Old 07-24-2015, 01:58 AM   #6
Trac Toy
Trac Toy's Avatar
@Raceseng
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 07-24-2015, 02:40 AM   #7
btoast
I put together some nice (imo) looking Punisher caps for my RPF1s for under $20 using parts off ebay. It's really not that hard. 68mm caps pop right in nice and snug.
btoast is offline   Reply With Quote
Old 07-24-2015, 11:36 AM   #8
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
Originally Posted by Kostamojen View Post
Link to purchase?
this
DuMa is offline   Reply With Quote
Old 07-24-2015, 12:00 PM   #9
cjd
cjd's Avatar
Drives: 2017 BRZ
Link to purchase?
I'll have to refer you to @Gruppe-s for that - I imagine a PM would get you an answer. There is a little info at the end of the TC105N thread I linked too.
Old 07-24-2015, 12:03 PM   #10
8R6
8R6's Avatar
Drives: FRS
@ohhwilliam
8R6 is offline   Reply With Quote
Old 07-24-2015, 12:29 PM   #11
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
holy cow this is insanely SMART!!!
Co-worker and I just lost our minds lol. AND they won't "fly off" at the track/while driving. Hi-five for this, hi-five.
Old 07-24-2015, 02:54 PM   #12
ryoma
ryoma's Avatar
now the question is, will they scratch up easily if you aren't extremely careful when mounting wheels? lol. I am definitely interested if they will make these for the RPF1's. I hate the Enkei center caps for the RPF1; it looks so cheap but I bought them anyways to not look like a cheap bastard and run wheels without center caps haha
Old 07-24-2015, 08:41 PM   #13
continuecrushing
plus they're freaking expensive, for what they are.
Old 07-31-2015, 04:25 PM   #14
HSC
Drives: Whiteout FR-S
Very interested...
HSC is offline   Reply With Quote
Offical Gruppe-S UEL Header Install & Review Thread continuecrushing Engine, Exhaust, Transmission 313 06-11-2023 03:54 PM
Gruppe-S Unequal length header UEL - good power, excellent sound/quality - must SEE! Gruppe-s Engine, Exhaust, Bolt-Ons 680 12-26-2022 09:46 PM
Drift-Office : Gruppe-S UEL Installed & Tuned! Drift-Office Engine, Exhaust, Transmission 32 02-02-2016 03:42 AM
Gruppe-S tahdizzle User/Vendor/Sponsor Reviews, Feedback, Comments 13 05-06-2015 11:30 AM
centering rings necessary? bakerr6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 03-24-2014 03:46 PM
