Old 09-24-2018, 11:54 AM   #1
Devin11498
Devin11498's Avatar
Drives: 2013 Subaru Brz Limited
Tire Size Examples for 18x8.5
Recently purchased a set of WORK Emotion D9R from japan for a really good deal. Traditionally would go with a 9.5 but like said i could not pass this up. Now im trying decide what size tire to run. If anyone here has a 18x8.5 wheel with one of the following tire sizes drop a pic
225/35/18
235/40/18
Mainly considering the 225 or 235 but also curious to see the stretch on a 215
215/35/18
215/40/18
Much appreciated
Devin11498 is offline   Reply With Quote
Old 09-24-2018, 12:33 PM   #2
meWant
Drives: '16 BRZ Limited
I had run 235/40/18 Hankook Ventus V12 evo2
But presently I run 255/35/18 Firestone Firehawk Indy 500.
I will try to get pictures up soon of the current set up
meWant is offline   Reply With Quote
The Following User Says Thank You to meWant For This Useful Post:
Devin11498 (09-24-2018)
Old 09-24-2018, 01:45 PM   #3
Devin11498
Devin11498's Avatar
Okay thank you. Do you have any closer pics of the 235, trying to see how much stretch if any on a 235 on a 8.5 wheel.
Old 09-24-2018, 02:05 PM   #4
arkanist
Drives: 2016 BRZ Limited, Stock
235 is ideal for 8"-8.5" wide wheels, there shouldn't really be much if any stretch. 225 is considered the minimum for 8.5" but you could totally stretch a 215.
arkanist is offline   Reply With Quote
The Following User Says Thank You to arkanist For This Useful Post:
Old 09-24-2018, 02:09 PM   #5
arkanist
https://tyrestretch.com/8.5-215-35-R18/
https://tyrestretch.com/8.5-215-40-R18/
https://tyrestretch.com/8.5-225-35-R18/
https://tyrestretch.com/8.5-225-40-R18/
Old 09-24-2018, 02:34 PM   #6
Devin11498
Devin11498's Avatar
I know that haha i actually have all those links saved on my phone. I just more or less want to see better pictures of a 225/35 and 235/40
Old 09-24-2018, 02:48 PM   #7
Tristor
Tristor's Avatar
I'm running 225/40/18 on 18x8.5" wheels and while it does seem to have a little bit of stretch, it seems to perform flawlessly and even then it has increased the overall diameter of the wheel/tire combo. (625mm to 637mm) which makes my speedo off slightly. 235/40 would be around 645mm diameter, so a full 20mm more than stock tire/wheel combo.
Why is there a belief that 235/40 is more proper than 225/40 in this case? 245/35 is closest in diameter (625mm to 629mm) and has almost non-existent speedo difference.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
Old 09-24-2018, 02:54 PM   #8
StraightOuttaCanadaEh
Wes
https://instagram.com/p/Biai4fIFnjZ/
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 09-24-2018, 02:55 PM   #9
Devin11498
Devin11498's Avatar
Do you have any photos of the small stretch? I dont really care about speedo stuff lol
Old 09-24-2018, 03:00 PM   #10
Devin11498
Devin11498's Avatar
oooo that looks like what i just about want. maybe i can get slightly more lip poke from a 235/35 since the sidewall in slightly smaller
Old 09-24-2018, 03:04 PM   #11
Wes
go for it. Look at my IG in case you wanna see more pics. I don't have one focusing just on the wheels unfortunately. There is a bit of a stretch though.
Instagram: @gt86ws
Old 09-24-2018, 03:06 PM   #12
Devin11498
Devin11498's Avatar
i just followed you. You have some pretty good photos tho to give me a ideas fitment wise.
The Following User Says Thank You to Devin11498 For This Useful Post:
StraightOuttaCanadaEh (09-24-2018)
Old 09-24-2018, 04:07 PM   #13
meWant
I can try finding some.
Old 09-24-2018, 04:31 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The number of 235/35/18 tires available is close to ZERO.
OP, tire width varies on brand and model quite a bit. Meaning a Michelin 225/40 will most likely look different than a 225/40 (enter brand) on a 18x8.5.
Example:
MPSS 245/35/18 tire = 9.2 tread width
MPS4S 245/35/18 tire = 8.4 tread width
I LIKE TIRES!
Max tire size with 18x8" +35 wheels? Turbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-23-2018 11:37 PM
I want 18x8.5" wheels, please help w/ tire size Lakitu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-20-2018 05:24 AM
Tire size help? XXR 530 18x8.75 +33mm cesar9127 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-10-2016 05:13 AM
Tire size for square 18x8.5+38 lowered on coilovers? B$ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-07-2015 06:50 PM
Tire size for 18x8 wheels?225/40 or 245/35 FT86RGV Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-06-2013 02:24 PM
