-   -   Tire Size Examples for 18x8.5 (https://www.ft86club.com/forums/showthread.php?t=130451)
Devin11498 09-24-2018 10:54 AM
Recently purchased a set of WORK Emotion D9R from japan for a really good deal. Traditionally would go with a 9.5 but like said i could not pass this up. Now im trying decide what size tire to run. If anyone here has a 18x8.5 wheel with one of the following tire sizes drop a pic :thanks:
225/35/18
235/40/18
Mainly considering the 225 or 235 but also curious to see the stretch on a 215
215/35/18
215/40/18
Much appreciated :w00t:
meWant 09-24-2018 11:33 AM
I had run 235/40/18 Hankook Ventus V12 evo2
http://i.imgur.com/3NFol5Q.jpg
But presently I run 255/35/18 Firestone Firehawk Indy 500.
I will try to get pictures up soon of the current set up
Devin11498 09-24-2018 12:45 PM
Okay thank you. Do you have any closer pics of the 235, trying to see how much stretch if any on a 235 on a 8.5 wheel.
arkanist 09-24-2018 01:05 PM
235 is ideal for 8"-8.5" wide wheels, there shouldn't really be much if any stretch. 225 is considered the minimum for 8.5" but you could totally stretch a 215.
arkanist 09-24-2018 01:09 PM
https://tyrestretch.com/8.5-215-35-R18/
https://tyrestretch.com/8.5-215-40-R18/
https://tyrestretch.com/8.5-225-35-R18/
https://tyrestretch.com/8.5-225-40-R18/
Devin11498 09-24-2018 01:34 PM
I know that haha i actually have all those links saved on my phone. I just more or less want to see better pictures of a 225/35 and 235/40 :thumbup:
Tristor 09-24-2018 01:48 PM
I'm running 225/40/18 on 18x8.5" wheels and while it does seem to have a little bit of stretch, it seems to perform flawlessly and even then it has increased the overall diameter of the wheel/tire combo. (625mm to 637mm) which makes my speedo off slightly. 235/40 would be around 645mm diameter, so a full 20mm more than stock tire/wheel combo.
Why is there a belief that 235/40 is more proper than 225/40 in this case? 245/35 is closest in diameter (625mm to 629mm) and has almost non-existent speedo difference.
StraightOuttaCanadaEh 09-24-2018 01:54 PM
225/40/18
https://instagram.com/p/Biai4fIFnjZ/
Devin11498 09-24-2018 01:55 PM
Do you have any photos of the small stretch? I dont really care about speedo stuff lol
Devin11498 09-24-2018 02:00 PM
Originally Posted by StraightOuttaCanadaEh (Post 3136810)
oooo that looks like what i just about want. maybe i can get slightly more lip poke from a 235/35 since the sidewall in slightly smaller
StraightOuttaCanadaEh 09-24-2018 02:04 PM
go for it. Look at my IG in case you wanna see more pics. I don't have one focusing just on the wheels unfortunately. There is a bit of a stretch though.
Devin11498 09-24-2018 02:06 PM
i just followed you. You have some pretty good photos tho to give me a ideas fitment wise.
meWant 09-24-2018 03:07 PM
I can try finding some.
http://i.imgur.com/4cJyuQI.jpg
http://i.imgur.com/sJEHA26.jpg
Leonardo 09-24-2018 03:31 PM
The number of 235/35/18 tires available is close to ZERO.
OP, tire width varies on brand and model quite a bit. Meaning a Michelin 225/40 will most likely look different than a 225/40 (enter brand) on a 18x8.5.
Example:
MPSS 245/35/18 tire = 9.2 tread width
MPS4S 245/35/18 tire = 8.4 tread width
