Old 05-21-2018, 01:37 AM   #1
Turbo
Drives: FR-S Turbo
Max tire size with 18x8" +35 wheels?
Hey guys - I'm curious if a 255/35R18 tire will work on an 18*8 +35 offset rim without rubbing?
Would like to run at all 4 corners using the stock suspension.
Turbo is offline   Reply With Quote
Old 05-21-2018, 01:43 AM   #2
dostoyevsky
Drives: 2017 BRZ
235 is the most i would go on 18x8
dostoyevsky is offline   Reply With Quote
Old 05-21-2018, 11:14 AM   #3
Turbo
Drives: FR-S Turbo
Due to rim/tire size issues or rubbing/interference?
Old 05-21-2018, 11:53 AM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I now have and would suggest 225/40/18 on 18x8 +35. I was using a 245/35/18s, but they made the steering heavy and mushy. Additionally, they fit under my fender because my wheels were +45 before I added a 10mm spacer.
225/40 is the perfect size for an 18x8. It adds a little width & height while keeping the steering feel precise.
IMO, A 255/35 will be pinched on an 18x8, look terrible, handle worse and probably rub. My rear is a 18x9 with 245/35/18. A 255/35/18 goes on a 18x9.5 wheel.
I LIKE TIRES!
Old 05-21-2018, 01:28 PM   #5
Turbo
Drives: FR-S Turbo
I should have qualified all this by saying my car is essentially going to be a track-day toy, that I drive to and from the track and a bit on weekends. I'm also boosted running about 320HP at the crank.
Right now I have the stock suspension, but will likely be installing coil-overs and big brakes before the summer is over.
For coil-overs I was thinking something higher end and on the brakes, maybe the Wilwood kit front & rear.
On that note, if anyone is aware of someone who has either for sale please feel free to put us in touch.
Old 05-21-2018, 02:04 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
100% Still 225/40. Or get wider wheels. More tire on the wrong wheel won't be better.
I LIKE TIRES!
Old 05-22-2018, 12:29 AM   #7
Turbo
Drives: FR-S Turbo
Thanks for the help-
OK - so I think I'm going to buy some wider rims then, as I think I'm going to need more meat on the road than 225's will give.
If I want to run a 255/35R18 square setup, that would mean 18x9.5" rims all around. Am I going to run into rubbing/interference issues doing this with the stock suspension?
Any recommendations on wheel offset?
Old 05-22-2018, 05:07 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No reason to run 18's unless you like the way it looks. Usually around a +35 offset. This will give you room to run bbk in the future.
If you are running 255 on stock suspension the tire starts to get too close to the strut. 245's on +38 offset were only about 1/4-3/8's away from the spring perch of the strut on my car. That is getting too close when you are going out on low tire pressure those first sessions in the morning.
Old 05-22-2018, 09:36 AM   #9
rebsinfx
Drives: 86
Will 245 40 18 fit on this size?
rebsinfx is offline   Reply With Quote
Old 05-22-2018, 09:38 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That would be over an inch taller then stock. 245/35/18 would be a lot closer to stock diameter.
Old 05-23-2018, 03:10 PM   #11
Turbo
Drives: FR-S Turbo
Does anyone know if the Wilwood big brake kit will fit inside a 17x8" rim like the Fast FC04? Thinking about going that route and running 245/40R18 RE-71R's.
Old 05-23-2018, 03:24 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Turbo: most aftermarket brake vendors provide brake fitment templates. You can try send those to wheel shop to check or if you already have wheels, print it out, glue on carton, cut out, and check clearance yourself.
Old 05-23-2018, 09:32 PM   #13
Turbo
Drives: FR-S Turbo
What are your thoughts on max tire size if I go down to a 17" rim? I like the idea of wheels that are a bit lighter and R-compound rubber that's a bit cheaper.
I was thinking a 245/40R17 on a 17x8 ET35 wheel on all 4 corners. Bridgestone says the RE71R in that size is fine on 8.0-9.5" rim widths, so I'm curious if running it on a wider (and heavier) 9" rim would gain me anything.
Old 05-23-2018, 09:36 PM   #14
Turbo
Drives: FR-S Turbo
Thanks, Church
I want 18x8.5" wheels, please help w/ tire size Lakitu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-20-2018 04:24 AM
Tire Size Recommendation for RE-71R on 18"x8.5" +42 RAYS 57Xtreme Wheels RJasonKlein Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-29-2016 11:12 AM
Tire size help? XXR 530 18x8.75 +33mm cesar9127 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-10-2016 04:13 AM
Tire size for square 18x8.5+38 lowered on coilovers? B$ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-07-2015 05:50 PM
Tire size for 18x8 wheels?225/40 or 245/35 FT86RGV Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-06-2013 01:24 PM
