Old 03-30-2018, 10:59 PM   #113
Anthonyc77
Drives: 2017 Toyota 86 Halo
Originally Posted by MJones_RB View Post
5. Spend a few extra $ and get your car corner balanced when you get it aligned. Worth it.
Just an FYI you can only corner balance your suspension if you have adjustable springs. Being that this DIY is mainly for lowering springs that do not have adjustment, you are just throwing your money at an alignment shop to not do anything. I understand this method can also be used if you have coilovers that did not come with top hats, if that is the case then yes a corner balance would be worth it.
Anthonyc77 is offline   Reply With Quote
The Following User Says Thank You to Anthonyc77 For This Useful Post:
MJones_RB (04-02-2018)
Old 04-02-2018, 07:01 PM   #114
HamburgerSushi
Drives: 2017 Subaru BRZ 6MT, Perf Pack
Hello! I think I have a problem...
Album for your enjoyment:
https://imgur.com/a/YCCUl
I just used this awesome method to install the springs, but I've run into a problem. I was checking the tightness of each shock top using both the pass-through wrench and the allen key. 3/4 four corners were tight and immobile, which is good. However, when I got to the rear left, I noticed that the nut spins freely while the shaft from the shock stays still.
So, in summary:
3/4 corners, nut spins with shaft, when nut is tightened with shaft held steady with allen key = no movement
1/4 corners, nut spins FREE of shaft, when nut is tightened with shaft held steady = nut continues to move freely
Weirdly, it's also completely asymptomatic. I am super sensitive to weird noises, especially when they weren't there before. Nothing new at all.
I've tried to maniacally screw down and unscrew the nut as well, but the nut does not move vertically at all with my attempts in BOTH directions.
Have I stripped the nut, or worse, the shock shaft?
I'm getting an impact driver adapter in the mail in a couple days, so hopefully I can sputter it off with that...
HamburgerSushi is offline   Reply With Quote
Old 04-06-2018, 03:16 PM   #115
HamburgerSushi
Photo bump.
The rear left is pictured here. The nut spins freely when the car is jacked up by the rear left control arm (I can spin it with my fingers). It is more difficult to spin with the car jacked up (more resistance to turning with ratchet). It does not move up or down with clockwise or counterclockwise turns. It spins independent of the hex center shaft. I tried using an impact wrench in every position with no luck.
This is the rear right nut. It is tight. Notice the basically identical thread engagement (9 threads on both left and right sides).
Any ideas?
I’ve been up to 120mph with this and no problems. The car does not exhibit any strange clunks or noises. What gives?!
Old 08-30-2018, 01:09 PM   #116
LotsaMiles
Drives: Scion FR-s, xB, iA, Silverado Z71 4
Originally Posted by jeebus View Post
I recently installed a set of RCE Yellow springs...
I'm at 152k miles on my 2013 daily driver. I've noticed a clunking coming out of the left rear and the shock is leaking oil. I just ordered from Amazon the ratchet and four kyb Excel G's (I just want my OEM performance, which is fine and fun). Total bill for four shocks, including tax, is $345.
I've never thought I could do struts before. Looks like we'll find out. Your instructions (along with the article to which you linked) inspired me.
Thank you.
LotsaMiles is offline   Reply With Quote
Old 08-30-2018, 01:21 PM   #117
LotsaMiles
A few points for anyone trying to do this DIY:
1. Always use jack stands. DO NOT trust your hydraulic jack.
2. DOn't worry too much about torquing the strut top bolt. Let the guy doing your alignment do that for you (2 weeks later).
3. Do an alignment 2 weeks later, after everything has settled.
4. Save yourself a lot of trouble and loosen your rear LCAs bolt. So much easier. Unbolt the end links for bonus ease.
Good luck!
What are LCA's and what is "corner balanced"?
Old 08-30-2018, 01:42 PM   #118
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
LCA = lower control arms.
Corner balance (via Google) = the process of shifting the weight carried by each wheel to approach optimal values. Although some weight can be shifted between wheels by physically relocating parts of the car, the corner balance process is focused on shifting weight by adjusting the suspension spring height.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-31-2018, 09:29 AM   #119
LotsaMiles
Thanks. I apologize for asking. I was able to google it.
Man, I'm really pushing my seventh set of tires now. Costco begins their Michelin sale next month and I need a new set of PSS's BAD. I actually put up a youtube video of me hydroplaning on I-65 and the SUV in front of me spinning out at 75 MPH. [ame="<div style="display: none;" id="ame_noshow_post_1535722181_2">
<a href="" title="YouTube" target="_blank">YouTube</a>
</div>
<div style="display: inline;" id="ame_doshow_post_1535722181_2">
<iframe width="640" height="410" src="//www.youtube.com/embed/b8lnmtqB56I?start=" frameborder="0" allowfullscreen></iframe>
</div>"]<div style="display: none;" id="ame_noshow_post_1535722181_3">
</div>
<div style="display: inline;" id="ame_doshow_post_1535722181_3">
</div>
[/ame]
You can see I need new rainx too.
Old 01-12-2023, 11:28 AM   #120
cicada
cicada's Avatar
Drives: 2018 Subaru BRZ with Perf Package
I just came here to report that I followed this DIY with the RCE yellow springs. I don't have the "Thank you" button yet, so please accept this message as my thank you.
cicada is offline   Reply With Quote
Old 01-17-2023, 09:28 AM   #121
WNDSRFR
Drives: FR-S,GTI
I just replaced the right rear shock and didn't have to compress the spring at all. I just removed the whole strut assembly and held the allen screw while removing the nut. There was no spring tension at all. Then transferred the spring, bump stop and cover to the new shock and remounted it. If you don't need to compress the spring to mount it then why would you have to compress it to dismount it?
*******IMPORTANT POINT******** I already had lowering springs. If you have OEM springs USE A SPRING COMPRESSOR.
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Exhaust MP/FP (flange/spring bolts) install help! rbizzle004 Engine, Exhaust, Transmission 9 03-04-2013 11:34 AM
East bay shops for spring install? WillBRZ Northern California 9 02-21-2013 02:03 AM
Selling stock strut/spring assembly SleekMachine Brakes, Suspension, Chassis 16 12-13-2012 08:03 PM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
