Old 03-03-2013, 09:22 PM   #1
rbizzle004
Exhaust MP/FP (flange/spring bolts) install help!
I installed the Nameless axle back and the front pipe over pipe combo. Need some help sealing the flange for the front pipe and mid pipe. I cannot get the spring bolts to seal it all the way.
One side were the bolt is wont seal fully but I can get the other side just fine. I'm having an issue getting the problem side bolt tensioned all the way down. In the process the threads of the bolt snapped. I have it temporarily rigged with an improper length bolt. Will be calling the dealership in the morning hoping they have some in stock.
Any advice on how to get the spring bolts tightened all the way down? I'm about to give up and just take get to a shop and pay them to tighten the bolts down and have it seal properly. Any advice would be appreciated.
rbizzle004 is offline   Reply With Quote
Old 03-03-2013, 09:37 PM   #2
sierra
Drives: Skoda Yeti DSG diesel 4x4
Surely the purpose of the springs is to supply enough tension to seal the joint but with some flexibility. Are you tightening then all the way down so the springs are fully compressed?
sierra is offline   Reply With Quote
Old 03-03-2013, 10:06 PM   #3
rbizzle004
That's the problem I couldn't get the one side fully compressed, which caused the threads on the bolt to snap trying to get it fully compressed.
Old 03-03-2013, 10:09 PM   #4
mad_sb
Drives: 2013 Asphalt FR-S
I just installed my over/front pipe last night and did not have any issues. i went in this order:
1. get the pipe in postion and on the header flange using the stock gasket
2. loosely put in the single front pipe support bolt
3. tighten the two botls at the header flange going a little at a time and alternating to snug them down evenly
4. install the spring bolts tighten them down a little at a time alternating between the two
5. tighten the center support bolt
you did remember to take the dounut gasket off the stock front pipe and put it on the nameless pipe correct? If not the joint will be loose when the bolts are bottomed out.
Did you already install the axle back? Did you use the nameless bushings? You always start at the front and work towards the back of the car when tightening down the bolts. My guess is you took up too much slack in the axle back section to get the midpipe sealed to the front pipe.
Old 03-03-2013, 10:44 PM   #5
rbizzle004
The first night I just installed the axle back and took off the factory over pipe and front pipe. Then today I installed the nameless FP/OP.
I had no issues bolting the OP to the header and I did alternate each bolt as I tightened everything for the whole exhaust and yes I used the factory gasket.
I will disconnect the axle back from the mid pipe and try to tighten down the FP/MP flange and see if that fixes the problem. Guess that make since wish i would have thought of that sooner. I'm just using the factory bushings.
Old 03-03-2013, 10:47 PM   #6
rbizzle004
Correction I did not use the other gasket for the FP and MP. Is it supposed to go there? I thought if came off the factory OP/FP flange?
Old 03-03-2013, 10:51 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I sheared one of those bolts, but it was because I did not put the donut gasket in Nameless DP, I left in in the stock one
Once I added the Donut gasket, it sealed perfectly.
Old 03-03-2013, 11:55 PM   #8
mad_sb
You have to use the factory doughnut gasket that connects the front pipe to the midpipe. It needs to slide off the mid pipe end of the factory front pipe and onto the midpipe end of the nameless front pipe.
Also, if you look at the spring bolts, they bottom out on the shoulder just above the tend of the threads so they can only be tightened so far. If you are shearing one of them it is because the bolt has bottomed out and is at the end of it's travel. Once you have the doughnut gasket on there you should be able to run the spring bolts down until they bottom out and you will have a factory seal.
Old 03-04-2013, 11:18 AM   #9
rbizzle004
Gotta love rookie mistakes. This was my first exhaust system I installed. I learned a lot. And yes my entire problem was because I forgot the donut gasket for the FP/MP.
Thank you everyone for your help. The exhaust sounds and looks amazing.
Old 03-04-2013, 11:34 AM   #10
mad_sb
we all make them from time to time
Remus Exhaust system to be released Late Winter/Early Spring for FRS/BRZ ModBargains.com Engine, Exhaust, Transmission 18 03-09-2015 04:10 AM
East bay shops for spring install? WillBRZ Northern California 9 02-21-2013 02:03 AM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
Header flange Silverdub Engine, Exhaust, Transmission 0 08-09-2012 07:43 PM
Is the flange for muffler a standard Subie size? Evil86 Engine, Exhaust, Bolt-Ons 1 06-11-2012 11:43 PM
