Old 01-18-2016, 03:31 AM   #99
Lorico
Drives: 2015 FRS
what happens if you turned the allen wrench all the way out? would it cause any damage? I've never seen a mcpherson stut with the allen wrench
Lorico is offline   Reply With Quote
Old 01-18-2016, 03:40 PM   #100
ryoma
ryoma's Avatar
are you referring to the one on the shock? you want to hold the allen key still since twisting it too much will eventually ruin the seals on your shocks. though, I am not sure about exactly how many turns will ruin it, but as long as the allen key is held relatively still and doesn't turn much then it should be fine
Old 03-01-2016, 01:40 PM   #101
speeddemon
Drives: Scion frs
Okay..so I have gone through this and DarrenDriven's DIY. I am confused about one thing. When do I tighten 4 top hat nuts? Should they be preloaded or not? I'm sure it's here somehwere I must have missed it..
speeddemon is offline   Reply With Quote
Old 03-01-2016, 04:13 PM   #102
ryoma
ryoma's Avatar
tighten them to spec with the car on the ground. of course, hand tight first with the car in the air
The Following User Says Thank You to ryoma For This Useful Post:
speeddemon (03-01-2016)
Old 03-07-2016, 08:59 PM   #103
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Thanks for this helpful thread. Such a breeze to install.
Kestrel is offline   Reply With Quote
Old 03-09-2016, 08:43 PM   #104
kberkel
kberkel's Avatar
Thanks for the tip!
Had never done anything like this. Took about 3-4 hours just figuring it out along the way. Undoing the rear strut screw took forever with my makeshift tool, but it worked fine.
kberkel is offline   Reply With Quote
Old 01-12-2017, 01:56 PM   #105
fr-s6MT
fr-s6MT's Avatar
Drives: White Scion FR-S
I did this today on the front to replace my oem frs springs with oem brz springs. All I did was unbolt the sway bar, pull the strut to the side, replace the springs and put it all back together. I did a pre load on the assembly using the jack, everything was too easy IMO. Thanks for the post!!! And anyone can do this really.
fr-s6MT is offline   Reply With Quote
Old 01-13-2017, 03:53 PM   #106
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
A few points for anyone trying to do this DIY:
1. Always use jack stands. DO NOT trust your hydraulic jack.
2. DOn't worry too much about torquing the strut top bolt. Let the guy doing your alignment do that for you (2 weeks later).
3. Do an alignment 2 weeks later, after everything has settled.
4. Save yourself a lot of trouble and loosen your rear LCAs bolt. So much easier. Unbolt the end links for bonus ease.
5. Spend a few extra $ and get your car corner balanced when you get it aligned. Worth it.
Good luck!
MJones_RB is offline   Reply With Quote
Old 03-08-2017, 04:50 PM   #107
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Huge thanks for this shortcut method! It works like a charm!
I just installed my STI springs. I feel so damn good about it too haha
I was going to have a shop do it, but once I got the price quote...I told myself no way...I'm going to do this!
Feel so accomplished....guys, you can do it too! Save your money and just get another set of helping hands
Use this guide for all the other steps
http://www.ft86club.com/forums/showthread.php?t=10842
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 04-06-2017, 11:37 AM   #108
rtalich
Drives: 2015 BRZ Series.Blue
Another Thank You post here! This method was awesome.
rtalich is offline   Reply With Quote
Old 06-03-2017, 12:46 PM   #109
Mithosphere
Fart-noise maker
Mithosphere's Avatar
Drives: 2014 Scion FR-S
Awesome, thank you for this!
I swapped springs last night, took a little longer than expected due to some difficulty removing the rears... and forgetting to tighten a couple of bolts on the rear LCAs.
Mithosphere is offline   Reply With Quote
Old 01-07-2018, 02:11 AM   #110
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Anyone know if this method will work with aftermarket springs? I did it the first time with the stock springs, but now I'm on shorter & stiffer springs - still think the same principles would apply...
Been on lowering springs for a while getting ready to swap in some Bilstein B8s & get off the stock shocks >_<
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 01-20-2018, 12:45 AM   #111
Phantobe
Phantobe's Avatar
Anyone tried this? Bump... getting ready to install soon.
Old 01-20-2018, 08:17 PM   #112
Phantobe
Phantobe's Avatar
All installed, you can use this method with a stiffer spring rate than stock. For anyone that cares.
There is less preload so it may even be easier than stock. Had to unbolt a couple bolts on the rear lca to get them unloaded fully.
Sent from my SM-G900V using Tapatalk
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Exhaust MP/FP (flange/spring bolts) install help! rbizzle004 Engine, Exhaust, Transmission 9 03-04-2013 11:34 AM
East bay shops for spring install? WillBRZ Northern California 9 02-21-2013 02:03 AM
Selling stock strut/spring assembly SleekMachine Brakes, Suspension, Chassis 16 12-13-2012 08:03 PM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
