Old 08-28-2018, 10:28 AM   #1
Sharpilot
Drives: 2013 Scion FRS
Oil viscosity in warm climate
Good afternoon,
Just wanted to get your opinion on something. I live in the Caribbean so the temperature doesn't go lower than 70F. Would it be fine to use a higher viscosity oil like 5W-30 since I don't have to worry about cold temps?
Sharpilot is offline   Reply With Quote
Old 08-28-2018, 10:49 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
You'll be fine with 5w30 but I'm from Florida and have had zero issues with running the recommended 0w30 in this climate.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-28-2018, 05:31 PM   #3
86MLR
86MLR's Avatar
Sydney Australia, 5w 30
Lowest temps I see are -2° C in winter during the night, highest is 45° C during the day in summer.
Average temps from 5° C to 30° C.
Old 08-28-2018, 08:21 PM   #4
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Florida too here, I just switched to 0W-30:
https://smile.amazon.com/Castrol-062.../dp/B007G7PUMS
Old 08-29-2018, 09:16 AM   #5
8RZ
The Gunshine State
8RZ's Avatar
Originally Posted by Yoshoobaroo View Post
Totally off topic, is your signature picture at the old geneva SSCA autocross spot?
No, this was in Brooksville.
Current DD: M235i
Old 08-29-2018, 06:58 PM   #6
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Sharpilot View Post
Good afternoon,
Thats what I do every spring/summer till fall, then back to 0w-20 for the winter months.
I believe that's what the manual recommends as well for hotter or more heavy duty use for this engine.
Intent > Content
Old 08-29-2018, 07:37 PM   #7
JIM THEO
Drives: BRZ 2018
I use 5W30 Redline (Viscosity is only one index, HTHS plays also a huge role) in Greece, from -5 to 40+C, but bear in mind STI sells 5W40 even for spirited street driving and Motul 5W40 for track use if that matters!
JIM THEO is offline   Reply With Quote
Old 09-13-2018, 07:42 AM   #8
chipmunk
Drives: _
Honest question:
As long as your thermostat is working, and the radiator fans kick in properly, what difference does this make if the ambient never drops to sub-zero?
chipmunk is offline   Reply With Quote
Forced Induction Oil Viscosity Towelly AUSTRALIA 7 03-05-2019 12:35 AM
Extremely Hot Weather - Engine Oil Viscosity Guru86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 11-22-2017 10:07 AM
Engine oil viscosity for hot climate redburn86 Engine, Exhaust, Transmission 6 08-10-2014 08:11 AM
**Best viscosity for frs and brz** 21_nola_05 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 05-29-2014 11:10 AM
Oil discussion (pressure, grades, viscosity, etc) - repost from Ferrari Chat mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 08-17-2013 12:46 PM
