Old 08-16-2013, 12:37 PM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Oil discussion (pressure, grades, viscosity, etc) - repost from Ferrari Chat
I found this thread many years ago, and figure it's helpful for those wanting to learn more about engine oils.
Feel free to read/bookmark, the info has served me well over the years.
http://ferrarichat.com/forum/faq.php?faq=haas_articles
Long story short, oil pressure is the important factor in your engine oil's performance. Everyone freaks out about how thin 0W-20 is, but it's not a big deal at the ideal temps.
-alex
Old 08-16-2013, 08:20 PM   #2
Suberman
Drives: Subaru BRZ Sport Tech Satin White
-alex
Oil pressure isn't the important factor as the article says. Oil pressure keeps the oil flowing through the bearings. Oil flow is the key. Oil flow keeps oil temperature in the bearing at an acceptable level. Bearing separation is achieved by the wedging action of the oil film under rotational forces which is one reason lugging an engine at very low rpm can damage the bearings, not because the oil pressure is too low but because the rotational speed of the bearing is too low. Film strength affects this quality of the oil, higher film strength generally gives better protection.
People tend to think the higher viscosity protects because it resists the forces moving the bearing and journal surfaces together. This is incorrect. Higher viscosity may be needed to keep the oil flow rate correct for your engine design. If the engine is designed for low viscosity oil then using higher viscosity can damage your engine.
If you put higher than recommended viscosity oil into your BRZ engine you can slow the flow rate down to the point the oil within the bearings gets too hot. Oil pressure will be high but flow rate will be low.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
504 (08-16-2013)
Old 08-16-2013, 08:56 PM   #3
dsgerbc
Drives: BRZ(sold), STI
Same thing in a much better-formated text is here.
dsgerbc is offline   Reply With Quote
The Following 2 Users Say Thank You to dsgerbc For This Useful Post:
ATL BRZ (08-21-2013), Suberman (08-16-2013)
Old 08-17-2013, 12:46 PM   #4
bluesubie
Good thread about oil film in bearings here. Lots of "noise" there, but a couple of good posters in that thread (Shannow and Molakule).
I always like to point out that Dr. Haas on Ferrarichat and bitog is a plastic surgeon.
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
dsgerbc (08-21-2013)
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 05:46 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 12:43 AM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 05:47 AM
Oil Pressure Specification Captain Snooze Engine, Exhaust, Transmission 0 12-05-2012 06:44 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
