Old 08-14-2018, 03:01 PM   #1
Kizer00X
Kizer00X's Avatar
Drives: Subaru BRZ pearl White
Tire sensor (TPMS) problems
I'm having a small problem with the TPMS not responding to my BRZ. I bought the car at a mazda dealership but I guess they missed the sensor light being on. They said they will fix it free of charge. Took it to them and spent my whole day there and they couldn't fix the light. Is this a subaru exlusive fix or are they missing something. No I'm not putting any tape to block the light lol no thanks.
Kizer00X is offline   Reply With Quote
Old 08-14-2018, 03:04 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Why did you take it to Mazduh?
The batteries may be dead in the sensors, buy some new ones. I see used sensors selling for $40ish.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-14-2018, 03:13 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I second this, the sensors are weak. Batteries are starting to die (if the car is a 2013/2014 I think a lot of us will need new sensors, I just had to do mine for this reason. One would go, then the next, etc)
Convince Mazduh to replace them. Make up a story if you must, but try to get new sensors to avoid putting your wheels on a tire machine more than necessary.
Old 08-14-2018, 03:13 PM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
They might be making a n00b mistake since it's a Mazda dealership and maybe they don't know that the Twins use TOYOTA TPMS sensors. SUBARU TPMS sensors won't work, as you can't program them into the ECU, since they have different IDs with the wrong number of digits.
Ask me how I know, lol.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Tcoat (08-14-2018)
Old 08-14-2018, 03:18 PM   #5
DarkPira7e
DarkPira7e's Avatar
The awesome part of this being that they are proximity based, so you can do the PVC tube trick and just leave them in the back seat if you wanted! Good tip though, I forgot about this.
Old 08-14-2018, 03:55 PM   #6
LOL just don't try to cross the border with the PVC pipe and sensors in the trunk. Guy on the Mitsu forum did it once and shut down the bridge to Detroit for 3 hours while the bomb squad responded and proceeded to blow his trunk apart with a high pressure water cannon. The pictures of the carnage were cool though. He was pretty sure he had convinced the border guards what it was but the bomb squad was having none of it.
FRSBRZGT86FAN (09-03-2018), Stang70Fastback (08-14-2018)
Old 08-14-2018, 04:27 PM   #7
Brink
Drives: 2017 BRZ
https://www.albanysubaru.com/
Brink is offline   Reply With Quote
Old 08-14-2018, 07:22 PM   #8
Kizer00X
Kizer00X's Avatar
Bought the car from them so figured I have to use their service.
Old 08-14-2018, 07:22 PM   #9
Kizer00X
Kizer00X's Avatar
Thanks for the info guys.
Old 08-16-2018, 06:12 PM   #10
Kizer00X
Kizer00X's Avatar
Took it back to Mazda and they fixed it. They ordered the tpms sensors from subaru and went to a tire shop and programmed them to the car. no more light, for now. thanks again guys.
Old 09-03-2018, 09:26 PM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
For future reference for anyone on that runs into this thread the part numbers are:
SU003-00754
28103-CA000 (subaru has CA001 or CA002 now)
And they can be programmed in using tech-stream or carista app under the system select menu or modifications menu under carista. If you're replacing one it's best to replace them all if they are legitimately past the 7 year mark and dieing, but they are quite expensive OEM, almost $97-$110 per sensor.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Kizer00X (09-06-2018)
Broke a TPMS sensor, process with ATEQ Quickset and new TPMS Sensor? Anthonyc77 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-19-2018 08:57 PM
Looking for 1 brz tpms sensor Sergeb96 Want-To-Buy Requests 0 01-23-2018 01:37 AM
FS: OEM TPMS Sensor username404 Wheels and Tires 2 05-06-2017 11:47 PM
TPMS sensor in spare tire? mit_peid Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 11-06-2014 12:07 AM
tpms sensor bkblitzed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 54 05-10-2014 03:03 PM
