Old 08-23-2013, 12:31 AM   #1
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
tpms sensor
Is it really needed? Ive always hand checked my tire pressure and never owned a car with a tpms in it. Just wondering because i got new wheels and they're mounted without me knowing the car has a tpms in it lol, so i would prefer to just throw em on without removing a tire and installing it.
bkblitzed is offline   Reply With Quote
Old 08-23-2013, 01:02 AM   #2
SliverBrz
Drives: Silver 2013 BRZ limited
Uhh it isn't needed but do you want that light on your dash?
SliverBrz is offline   Reply With Quote
Old 08-23-2013, 01:03 AM   #3
Anaxilus
Drives: They have four wheels
No. You can clear the light.
Anaxilus is offline   Reply With Quote
Old 08-23-2013, 01:11 AM   #4
bkblitzed
is better than you
bkblitzed's Avatar
I was just worried since some cars wont let you cancel traction. But if that doesn't matter in our cars than fuck it ima keep em off.
Old 08-23-2013, 08:47 AM   #5
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
How do you disable it?
TheseColorsDontRun is offline   Reply With Quote
Old 08-23-2013, 05:12 PM   #6
red_comet
Severed Member
red_comet's Avatar
Drives: Argento 2013 Scion FR-S Manual
+1
Id like to know, too
87 Volvo 760 Turbo <3
02 WRX THE QUEEN IS DEAD, LONG LIVE THE QUEEN!
06 Xfire Bite me I liked it
13 FRS doriftoooo!
DON'T PANIC
red_comet is offline   Reply With Quote
The Following User Says Thank You to red_comet For This Useful Post:
ftc~brz (09-17-2013)
Old 08-23-2013, 09:55 PM   #7
The_Societan
The_Societan's Avatar
Drives: Firestorm FR-S
Left for work today and noticed the car was having difficulty staying in a straight line when I accelerated. Then I noticed my TPMS light a moment later. When I got to the gas station, I checked my tires, but they looked fine. Then I checked again when I got to work, and the left rear tire was a little low. These tires don't show underinflation like I'm used to. Thankfully I have a little emergency air compressor that plugs into the 12V outlet... I was able to fill it back up so I could get home. But I'm going into the dealer tomorrow to have them fix it.
I am never going to turn off that TPMS indicator. I know some folks have changed wheels and either didn't want them in the new ones(for weight reduction purposes, ha) or just didn't want to pay to have them installed. But I think they are a valuable thing to have.
I wonder if the dealer will fix my tire under warranty... (3700 miles) Going in first thing tomorrow
The_Societan is offline   Reply With Quote
Old 08-24-2013, 03:44 PM   #8
BOLT
Drives: FS FT86
Originally Posted by red_comet View Post
+1
You cannot ever disable your tire pressure warning light/indication system. There are certain situations where your tpm system will warn you of another problem not only to do with tire pressure such as a faulty wheel speed sensor or wheel bearing. I think having this system is a luxury, low end models will not have this. Especially if your not rocking run flats you'll save the cost of a brand new tire if you ever puncture it.
BOLT is offline   Reply With Quote
Old 08-24-2013, 06:29 PM   #9
wparsons
wparsons's Avatar
The TPMS system on these cars won't warn you about a wheel speed sensor or bearing, they have actual pressure sensors inside the tire and don't rely on wheel speed readings, etc.
As for disabling TC/etc, not having TPMS' doesn't effect anything at all except the light on the dash. I run my snows without sensors and I can still totally disable TC/VSC anytime just like usual.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
red_comet (08-24-2013)
Old 08-24-2013, 07:42 PM   #10
BOLT
Drives: FS FT86
Like I said.. In certain situations a wheel speed sensor will be reading a normal rpm value rating but the abnormal frequency of the broken WSS will actually disturb the tpm sensor and illuminate the warning light. Obviously there is "actual" pressure sensors.. This is common sense via the thread title.. Tire pressure monitoring system sensor. My point is that this system serves a purpose so use it, takes 5 minutes to swap 4 sensors to a new set of rims
Old 08-24-2013, 07:53 PM   #11
foursix86
Drives: 13 FR-S
No, a faulty wheel speed sensor will never illuminate the TPMS lamp. The ABS lamp; yes.
foursix86 is offline   Reply With Quote
Old 08-24-2013, 08:44 PM   #12
BOLT
Drives: FS FT86
Anything creating interference with the signal (frequency) in between the sensor and ECM will illuminate the tpms lamp. By the way I love lamp, No.. It's Malfunction Indicating Light, MIL. Disprove my statement than, I demand an explanation.
Old 08-25-2013, 05:23 PM   #13
foursix86
Drives: 13 FR-S
MIL=Malfunction Indicator Lamp, or more commonly called the "check engine light". The TPMS lamp is turned on or off by the door control receiver, which is located under the package tray. It's also the module that receives RKE commands. It's an RF receiver. The TPMS sensors transmit to this module. Wheel speed sensors have nothing to do with TPMS in reference to the FR-S/BRZ. Now if we were discussing VW Jetta/Passat/etc., then yes; the wheel speed sensors in those cars are responsible for turning on the TPMS lamp. That system works by detecting a tire that is deflated below threshold by measuring how many revs per time unit each wheel is rotating. A more deflated tire has a smaller diameter and will therefore have more revolutions per time unit and thus signal the appropriate module to illuminate the TPMS lamp.
Old 08-26-2013, 10:52 AM   #14
wparsons
wparsons's Avatar
Lots of german cars run TPMS systems without pressure sensors, they use wheel speed readings to determine if a tire is low.
flickr
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
TPMS Sensor Issues gvan1998 Scion FR-S / Toyota 86 GT86 General Forum 4 04-28-2013 06:48 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 01:06 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
