Drives: 2017 Toyota 86 Halo
Broke a TPMS sensor, process with ATEQ Quickset and new TPMS Sensor?
Hello, recently broke one of my TPMS sensor's removing the tires from the my stock wheels. I purchased a new TPMS sensor (Denso 550-0105 TPMS Sensor) and the ATEQ quickset tool.
In doing some research, some people have noted with other platforms they needed to activate or awaken the sensor with a different tool before using the quickset. For anyone that has experience doing this, do I need to activate the sensor first, or can I just enter the code on the sensor into the quickset software. Thanks in advance. |
Bump
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Two things you need first, the ID code from the new TPMS sensor, as well as from the broken TPMS sensor. These are printed in a number/letter combination on the TPMS sensors themselves.
Did you write down the ID codes from both TPMS sensors prior to any changes? If not, then you cannot really do anything with the ATEQ Quickset tool. The ATEQ Quickset tool only allows you to pull the 4 ID codes stored on the car's ECU (one of them would be the broken TPMS sensor) via the OBD2 port onto the tool in where you can load the 4 ID codes onto the ATEQ software on a laptop. Once in the software, you need to find the broken TPMS sensor ID code, and replace it with the new TPMS sensor ID code. Then, you can load that information back onto the tool, and back into the car via the OBD2 port. |
#4 | |
Drives: '14 Asphalt FR-S
You will need "wake" the sensor before programming with the Quickset. At least that is my experience with the brand Tire Rack sells. Other manufacturers could be different. I used the cheapest activation tool that Tire Rack sells (VT15), then proceeded with the Quickset.
Sent from my SM-J510MN using Tapatalk Last edited by KryptoNate; 03-18-2018 at 03:48 PM. Reason: Clarification |
#6 | |
Don't spend your money on a tool to wake the sensor. It will wake up automatically when you start driving, and when your ECU transmits the new code to find the sensor.
I bought 4 of the Denso 550-0105 to use for my winter wheels. Entered all the new ID codes onto the ATEQ Quickset software after I pulled my 4 ID codes for my summer wheels from the car's ECU. Exported and stored all eight codes onto ATEQ Quickset tool, and use the winter/summer buttons accordingly when I swap wheels. I never had to wake up my new sensors for my winter wheels when I did it the first time. Although my TPMS light was on for a minute or two, it will eventually shut off after the reprogramming with the ATEQ Quickset tool. |
| ATEQ TPMS Quickset | rm125chris | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 02-14-2018 02:43 PM |
| ATEQ TPMS Quickset Programmer | Dan37BRZ | Wheels and Tires | 5 | 06-05-2017 09:38 PM |
| ATEQ QuickSet TPMS tool | B-R-Z | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 04-25-2014 08:17 PM |
| Has anyone tried ATEQ TPMS Quickset for our cars? | pheoxs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 11-29-2013 03:26 PM |
| Anyone use an ATEQ TPMS Quickset? | Foobar | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 04-06-2013 12:59 AM |
