Old 08-09-2018, 11:35 AM   #15
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
krayzie is offline   Reply With Quote
Old 08-09-2018, 12:57 PM   #16
Gunman
Drives: 2019 Mazda Miata RF
Yes, I can put my car in Drive and then pull my shifter to the left to engage "manual mode". Then the shifter should push forward and back to change gears.
It does, but as a warning to anyone using it this way, the shifting is backwards. Look at the + and - near the selector. Every race car I've ever worked on was 180° from that, and my first attempt at using it resulted in a surprising down shift, instead of up, LOL. It was also the last time.
The Following User Says Thank You to Gunman For This Useful Post:
Leonardo (08-09-2018)
Old 08-09-2018, 02:07 PM   #17
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Just swap the pins. There is a DIY on here somewhere with which ones to swap.
All Toyota cars are backwards like this for whatever reason.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Gunman (08-10-2018), Leonardo (08-09-2018)
Old 08-09-2018, 04:21 PM   #18
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Could just buy a longer shift knob.
tyler_win_photo is offline   Reply With Quote
The Following 2 Users Say Thank You to tyler_win_photo For This Useful Post:
chaoskaze (08-09-2018), humfrz (08-09-2018)
Old 08-09-2018, 04:45 PM   #19
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Talking
man we try to stay classy here
Old 08-09-2018, 08:54 PM   #20
There ya go -
Old 08-10-2018, 12:57 AM   #21
Aluma007
Drives: 2017 Brz
Originally Posted by HKz View Post
..you can also still use the paddles during normal D but after a few moments if you don't continue to use the paddles it goes back to being full auto.
I was aware of that one, thanks though... tried out the shifter up and down, its a little more fun than the paddles.
btw, check out sickspeed products on ebay, I have the adaptor( kind of like the manuals lift for reverse part) and a pearl shiftknob. I used the adaptor under the shift boot for a clean OEM look, but if you use it above the boot, its like an extension.
Aluma007 is offline   Reply With Quote
Old 08-10-2018, 01:10 AM   #22
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Cool
Originally Posted by Aluma007 View Post
check out sickspeed products on ebay.
https://www.sickspeed.com/product/pi...bust-10-x-1-25
Mother of God
Old 08-10-2018, 12:49 PM   #23
Gunman
I've seen it, I just prefer the paddles, hands on wheel
pinoy_dorifto (08-11-2018)
Old 08-10-2018, 01:08 PM   #24
finch1750
finch1750's Avatar
Yeah, when driving hard I use the paddles only. But just cruising around in a scenario manual works better (like rolling hills, traffic where I'm looking to pass, etc) I tend to use the shifter. And muscle memory from racing games and other cars I have driven is just too much lol
Old 08-10-2018, 01:09 PM   #25
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Exactly the same!
leevanf is offline   Reply With Quote
Old 08-10-2018, 02:20 PM   #26
Thaeyo
Thaeyo's Avatar
Also you will need an adapter for the boot retainer, otherwise you'll have the exposed metal
Thaeyo is offline   Reply With Quote
Old 08-11-2018, 06:25 PM   #27
Aluma007
Drives: 2017 Brz
Originally Posted by chaoskaze View Post
there, see that black piece under the purple...thats the adapter...I got mine in silver and installed it first, then the boot goes over it so there's no exposed shifter stick. The way its installed in the pic is on top of the boot which extends the knob up.
18x9.5 stock height stock struts etherealfall Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-11-2017 06:44 AM
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 10:57 PM
Coilover options capable of slightly increasing ride height. Mechazawa Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-31-2014 02:23 PM
Post Your Stock Height 86! VakaGT FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 03-19-2014 08:09 AM
BRZ vs 86 stock ride height Moe AFRICA 2 11-21-2013 09:35 AM
