Old 12-31-2014, 01:19 PM   #1
Mechazawa
Drives: FR-S, 6MT, White
Coilover options capable of slightly increasing ride height.
Hi, I think this is my first time starting a thread on here.
I have had my 13 fr-s from new and am around 35K miles. At the rate I am going I might be looking at at least replacing the dampers in the spring--I can feel some degradation in the rear at least.
I have been very happy with the stock suspension, and only drive this car on the street--though my driving style is what you might call "aggressive". With the reasonable prices for aftermarket suspension I want to try to find something that does what the stock suspension does, but a little better.
My first thought was to go with billstein dampers and some stock diameter springs, but I had the thought that it might be nice to be able adjust ride height. My thinking was that I would like to go maybe 20mm lower than stock in the warmer months, but 10mm higher in the winter--the extra ground clearance can be a big help in heavy snow.
Is anyone aware of some reasonably priced coilover options that will work well with slightly increased ride height but still improve handling a bit when set to a lower ride height--without too much sacrifice in ride quality. I know most coilover sets have shorter dampers. Maybe something custom from ground control?
Looking to keep the budget under $2000 if I can.
Thanks!
Mechazawa is offline   Reply With Quote
Old 12-31-2014, 01:22 PM   #2
DAEMANO
Time Traveller
Don't know of any shock / strut options, but since you're only looking to go 10mm higher have you considered a slightly taller winter tire (say 50-55 series)?
Old 12-31-2014, 01:34 PM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
Some of the RS-R coilovers seem to allow this if their range numbers are accurate, though I have no idea what this does for available droop travel and how well it would work in practice.
Old 12-31-2014, 01:48 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
for sure Ohlins can do it.
-alex
Old 12-31-2014, 01:56 PM   #5
Mechazawa
Excellent suggestion, but I am already running 195 60 16 snow tires (hakkapeliitta r2). Looking for a bit more on top of that.
Old 12-31-2014, 01:58 PM   #6
DAEMANO
Time Traveller
Have you considered one of these?
The Following User Says Thank You to DAEMANO For This Useful Post:
Captain Snooze (12-31-2014)
Old 12-31-2014, 02:23 PM   #7
Mechazawa
Lol--the snow tire choice may be a little bit over - optimized, but they sure do get the job done. It's part of the reason I am reluctant to go with a fixed lower ride height. I could end up with the snow tires rubbing inside the fenders. No rubbing at stock ride height though.
Coilover to Raise Ride Height Furtive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-28-2014 01:57 PM
BRZ vs 86 stock ride height Moe AFRICA 2 11-21-2013 09:35 AM
Coilover self install, what's the best way to ensure proper ride height? Sensisnow Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-05-2013 12:00 PM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 07:31 PM
