Old 09-02-2013, 09:20 AM   #1
etherealfall
Drives: Toyota 86 GTS Storm Black
18x9.5 stock height stock struts
Hey guys
Any one have any idea about fitment of 235 or 245 on stock struts at stock height? Offset +34; 18x9.5.
Things I'm looking for - any need for RCAs (at Sportline drop and at stock height) and any need for fender work. I believe they will clear the strut at normal height but what about at a Sportline drop level?
Thanks
Pete
etherealfall is offline   Reply With Quote
Old 09-02-2013, 09:54 AM   #2
TNPerformance
Drives: 2013 Hot Lava FRS/97 Supra/93 Supra
You should be fine. I have 18x9.5 +38 on all four corners. I also have a 255/35 on all four corners. At stock height with stock struts/springs I had no issues. It was CLOSE on the front, but still no issues. By close, I mean the tire against the bottom spring perch on the factory strut. Also, since you would be on a skinnier tire with an additional +4mm of clearance, that would just mean it'd fit even better. The rear clears everything no problem. Not sure on a lowering spring as I have since went with fully adjustable coilovers.
TNPerformance is offline   Reply With Quote
Old 09-02-2013, 03:02 PM   #3
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
When I test fitted my 18x9.5s +38 on 255/35 before installing the Coilovers I had no clearance. The tire was touching the strut. I believe I tested them on the front, so I don't know about the rear. But you have a 34 offset so you're probably good, except for the wheels sticking out way too much.
Asphaltfrs1 is offline   Reply With Quote
Old 09-02-2013, 03:36 PM   #4
TNPerformance
Mine was REALLY close (probably 3mm) but never actually touched. I drove around like this for a few days without any rubbing issues, even at full lock.
Old 09-02-2013, 04:27 PM   #5
FR-S Matt
Cleared the stock front spring barely on 18X9.5's, 245/35 tires squared. Rear was not an issue. On full coilovers now though.
Old 03-15-2014, 09:24 PM   #6
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Apologies for the necro bump, but would the Enkei NT-03M 18x9.5 +40 fit on a car lowered 1" all around on Swift springs + stock struts? I know that the 17x9 +35 fitment clears but not sure what that means if I pump it up a notch in sizing.
Edit: I'm looking to get tires to match, no crazy stretching business or excessive camber
leicaboss is offline   Reply With Quote
Old 06-16-2017, 03:37 AM   #7
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
I hope so ! I was considering the DOSS FF2 wheels & haven't lowered my car yet. They seem to only come in 18x9.5
rookietopro_frs is offline   Reply With Quote
Old 07-11-2017, 05:44 AM   #8
Fainten
Fainten's Avatar
Drives: white brz
I have the Doss FF3 18x9.5 +35 and I'm looking if its gonna clear everything with stock suspension with a 245 tire. Can someone confirm if this fit? i will go coils but later
Fainten is offline   Reply With Quote
Stock ride height numbers? xwd Tracking / Autocross / HPDE / Drifting 16 07-11-2018 12:42 PM
Your FAVORITE Rims on STOCK Height taimysho0 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-21-2013 09:40 AM
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 01:38 AM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
