Drives: 2014 BRZ Limited A/T
Increasing height of stock AT shifter?
Do you guys know of any shifter extender that increases the height of the OEM A/T shifter?
I want it a bit higher since im usually on manual mode, and prefer the shifter over the paddles. I noticed Raceng has an extender with the AT's dimensions but for some reason, the M10x1.25mm does not list the frs in the list of compatible cars. https://www.raceseng.com/extender-100 Thank you! |
Drives: 2016 Halo FRS
The product you linked is very expensive for what it is. Just a piece of bar stock with a threaded section and tapped hole.
If you are handy and had the right tools you could probably get a tap and die with the same thread pitch the auto shift know uses and make your own. Or just buy one lol. |
#3 | |
Country Boy 4 Life
I googled "shift knob extender" a bunch of stuff came up. I am sure if you took the time to sift through the results, you could find something that would work at a fair price. ( I mean it is just a threaded metal rod - How much do you want to pay? )
I LIKE TIRES! |
Drives: 2017 Brz
you can manual shift with the knob?? mine doesn't have that feature, It doesn't go up or down on the lever, just to the left to engage the paddles.
Drives: 2015 BRZ
Try it again, i know it feels like it doesnt shift up or down. I drove my friends 860 and i could shift from the knob just fine. It should have the "+/-" for shifting up and down.
#6 | |
Country Boy 4 Life
Yes, I can put my car in Drive and then pull my shifter to the left to engage "manual mode". Then the shifter should push forward and back to change gears.
I LIKE TIRES! |
Drives: 2017 Brz
INTERESTING! i'll try next time i go out
#8 | |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
..you can also still use the paddles during normal D but after a few moments if you don't continue to use the paddles it goes back to being full auto. |
The Fail Boat
Drives: CWP S.B.
#10 | |
Now if you wantta go old school
#11 | |
![]() humfrz |
#12 |
The Fail Boat
Drives: CWP S.B.
Man you guys do not disappoint.
![]() ![]() You came you saw and you conquered.
#13 |
The replies are hilarious guys! But seriously i just want to know will the Raceng one fit? I of course like the material and finish of it too..
#14 |
pessimistic skeptic
This adapter might be useful for fitting taller shift knobs made for manual
https://www.amazon.com/Kei-Project-S.../dp/B01H2SPAWU |
| 18x9.5 stock height stock struts | etherealfall | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-11-2017 05:44 AM |
| FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 09:57 PM |
| Coilover options capable of slightly increasing ride height. | Mechazawa | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-31-2014 01:23 PM |
| Post Your Stock Height 86! | VakaGT | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 03-19-2014 07:09 AM |
| BRZ vs 86 stock ride height | Moe | AFRICA | 2 | 11-21-2013 08:35 AM |
