Drives: BRZ Limited; GR86
whole lot of weirdness/possible overheating
So I got a new tune revision from my tuner and I flashed the car. After doing so, I went to log and everything seemed normal at first but I noticed a bit of burning smell (the type that you get when you buy a new car). looked under the hood but nothing seemed out of ordinary. Then my car started to idle roughly and the check engine light came on (the code was a p0011). I noticed the vvt intake was at -30. At this point, I thought it was possible that the tune was the issue. I swapped CAM sensors just to be sure but still got the same code. The next day I drove to the gas station and everything was normal and on the way back, the vvt started to go up to -30 again (burning smell present again). luckily I was on the highway and not very far from my house. Within a few min I got a check engine again. I looked at my gauges and coolant temp was at 98, oil temp was at 99. I decided to drive it home since I was a mile away. I got home checked under the hood and at this point i didn't know what was going on with the car. As I was looking for possible issues, my flash light fell into the bay. When I went to grab it, I noticed the coolant hose was completely off.
No clue how it happened but i'm suspecting something might have hit it. The coolant reservoir was sitting at midway so i never suspected that i had no coolant. reattached the hose and made sure to bleed the system. The car stopped throwing the p0011 code and seems to work fine. The temp gauge never indicated the car was overheating, probably since there was no coolant inside and the oil temp was always around a 100c. Anyone know the damages that could have been caused by this? The car drives fine for all I know. I was going to use a gas analyzer to test for hydrocarbons in the radiator to see if my head gasket could be damaged. Any other ideas would be greatly appreciated! |
#2 | |
Wheels for Brains
Other than that, do the usual sniff/smoke test from your exhaust. |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | shaynek (08-01-2018) |
#3 |
Oh, yours hasn't been the first car to blow a coolant hose.
If it runs OK now, I reckon you dodged a bullet. I'd just suggest you make sure you have your cell phone with you for the next few miles of driving. I hope it's OK. humfrz |
#4 | |
| The Following User Says Thank You to shaynek For This Useful Post: | humfrz (07-31-2018) |
#5 |
#6 |
Drives: 2017 BRZ Limited, Perf Package
Even if there is no coolant passing over the temp sensor, it is still reading air temp. I don't think you have done any long term damage, you would have noticed it by now.
#7 |
Drives: Track preped NA FRS
Just came in to say that my car was pumping air into the coolant (head gasket had a small fissure), and once there is enough air to form a pocket around the sensor the temp gauge will go all the way to the max and you will get a check engine light (coolant circuit voltage low or something like that). So if you didnt get that code it means you still had coolant in the engine. If it was too cool for the thermostat to open, then it could've been saved by that fact (not circulating thru rad). For a coolant hose to get lose like that (assuming you still have a skid plate), it was probably pressure inside the system, I dont see how something would go thru the skid plate, disconnect the hose and out without ripping off the underbody completely. Test for carbon on coolant. My fissure was small enough that I continued tracking the car for 8 more track days and a couple of months of daily before it got bad where I couldnt complete a single lap on track before there were huge pockets of air into the system.
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | shaynek (08-01-2018) |
#8 | |
| CEL/Cruise Control weirdness | MuseChaser | Issues | Warranty | Recalls / TSB | 10 | 09-01-2016 12:38 AM |
| BRZ overheating | Notso | BRZ First-Gen (2012+) — General Topics | 67 | 06-25-2016 12:01 PM |
| Massive Overheating Incident | mitosis | Issues | Warranty | Recalls / TSB | 26 | 11-18-2013 07:12 AM |
| Heater control weirdness | FRiSson | Issues | Warranty | Recalls / TSB | 0 | 03-29-2013 10:33 AM |
| Auto headlight weirdness | Grimlock | BRZ First-Gen (2012+) — General Topics | 9 | 06-05-2012 02:40 PM |
