Old 08-26-2016, 12:18 PM   #1
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
CEL/Cruise Control weirdness
Well, we just got back from our second 22-hour-round-trip jaunt from central NYS to OBX, NC in the FR-S and had our usual great time. On the third day down there, I activated the cruise control as I had been doing routinely over the trip. The green cruise control-on light came on as yellow and the CEL came on too. We were out in the middle of nowhere and the nearest dealership was over an hour and a half away. Pulled over, checked the fluids (engine oil, coolant, brake, and clutch), belt, and as many vacuum hose connections as I could find w/out burning myself too bad. All was good, so I just kept driving keeping an eye on engine temp and gas mileage. No issues; temp stayed right where it always was and gas mileage was in its typical awesome range. CEL light stayed on for a day. On the second day, on a whim I pulled off the cover to the fuses. Lots of fine gritty sandy stuff in there, so I wiped off some of it and pushed on the fuses to make sure they were all seated well. No evidence of blown fuses. The next day, the CEL light was off and the CC worked again.
No further hiccups at all for the rest of trip, including the 11 hour drive home. It WAS VERY hot when the light came on... upper 90sF for the first two days we were down there.
Ideas?
Thanks..
MuseChaser is offline   Reply With Quote
Old 08-26-2016, 12:29 PM   #2
jvincent
jvincent's Avatar
Without knowing the code, my guess would be the gas cap not being tightened properly.
That will throw a CEL and go away after you tighten it, which you probably did after filling up.
Old 08-26-2016, 12:42 PM   #3
Icecreamtruk
Drives: Track preped NA FRS
Maybe a coil pack. Those can appear on track during to the amount of heat but usually will go away or stay off if you clear them after the track day is over. I know you were not on the track, but you did mention it was really hot, so it could be a posibility.
Old 08-26-2016, 12:50 PM   #4
MuseChaser
MuseChaser's Avatar
Thanks to both of you for the quick replies..
Yeah, that's the first thing that anyone should check. No fillups were done in close proximity to the time the CEL came on, nor until well after it went out. Good call, but that wasn't it.
Entirely possible. I didn't reset anything; would the code still be stored even the CEL is now out? I'm due for an oil change (by my standards, although still have quite a ways until the suggested intervals), so I may just go to the dealership now that we're home and let them check it out this time.
Thanks again, guys.
Barry
Old 08-26-2016, 01:00 PM   #5
Could be damn near any sensor in the car really. Probably 100 different things it could have been. Obviously not serious if it cleared it's self but the code could still be there if you take to somebody that can read it.
Old 08-26-2016, 07:23 PM   #6
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Anybody's guess as to the CEL.
I can clear up your confusion about the cruise control, though.
Cruise control is disabled with the CEL on.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 08-27-2016, 06:43 PM   #7
Mr Nerd
Mr Nerd's Avatar
When I first purchased my car I had this also happen to me. As I was pulling out of work I had accidentally activated CC while I was in mid-drift with the tires spinning freely. My assumption was that the engagement of the traction control while in CC had triggered the CEL. The CEL was gone by the next time I started the car so I was never able to retrieve the code. Obviously, you were not mid-drift but I feel this info may be valuable to anyone whom may be reading this thread in the future in an attempt to narrow down the possible causes to their issue.
Mr Nerd is offline   Reply With Quote
Old 08-27-2016, 07:38 PM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Don't disconnect the battery or reset the codes. That info (in most cars anyway- I assume in the,Twins too) is stored in memory and can be retrieved with other data from the time of the event. Not at an Autozone, but at a garage with the right tool.
Invest $40 on an OBD2 port scanner and Torque Pro if you have a smart phone. Very helpful at odd times. I use mine everyday.
Old 08-27-2016, 08:19 PM   #9
Mr Nerd
Mr Nerd's Avatar
I'm glad you posted this. Now that I think about it, I DID get the code via Torque. I will update in a little while, just need to grab my tablet.
Old 08-27-2016, 09:19 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
OBDII code reader is $20 and most of the basic ones can at least clear the code so you can attempt to drive further.
-alex
Old 09-01-2016, 12:38 AM   #11
Mr Nerd
Mr Nerd's Avatar
The code I pulled was U0073
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
Cruise Control nospoons Scion FR-S / Toyota 86 GT86 General Forum 34 06-17-2014 02:28 PM
Can I use cruise control just after 1k miles? Weeber Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 12-27-2013 06:41 PM
Cruise control notout86 Scion FR-S / Toyota 86 GT86 General Forum 50 05-13-2013 02:01 AM
Heater control weirdness FRiSson Issues | Warranty | Recalls / TSB 0 03-29-2013 10:33 AM
