Old 06-22-2018, 03:48 PM   #57
bryan.catano93
Drives: 2013 frs
Bummer. I was sure that I had figured it out. Do they offer a PTE wastegate as an option or on earlier versions? Because the current version has the Turbosmart 38mm as the wastegate that comes with their kit.
now i have a question. im still technically overboosting. so i have the same issue. can i tune around it if lets say it holds around 8psi solid?
Sent from my VTR-L09 using Tapatalk
bryan.catano93 is offline   Reply With Quote
Old 06-22-2018, 03:57 PM   #58
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I don’t know if this is possible, but it could be if the inlet and outlet flanges are the same size; do you have the wastegate on backwards?
You are asking that if you can find a spring combo that holds 8psi, should you, even if that is not what the spring/s are rated for? If I were you, I would want to resolve the issue. Maybe replace the wastegate with a friend’s wastegate to eliminate that as a possibility. It just doesn’t seem safe.
Old 06-22-2018, 06:20 PM   #59
Kodename47
Kodename47's Avatar
Drives: UK GT86
You could so long as the tune is solid and done for that boost pressure. Just need to raise the boost cut level.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-22-2018, 07:38 PM   #60
bryan.catano93
Drives: 2013 frs
yeah id have to make sure the boost is constant, not too much as id like. to stay at 8psi. and the tune is good.
Old 06-22-2018, 07:40 PM   #61
bryan.catano93
Drives: 2013 frs
i was doing some research about the wg opening above the spring rating and someone mentioned backpressure. i have a trd catback which according to some. its got some 2.25 bends and its not the greatest for performance. could that harm the wg opening accuracy?
Old 06-22-2018, 07:42 PM   #62
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I still expect this threat to be about jerking off while flooring the car. I mean, am I the only one?
The Following User Says Thank You to EAGLE5 For This Useful Post:
Irace86.2.0 (06-22-2018)
Old 06-22-2018, 07:43 PM   #63
bryan.catano93
Drives: 2013 frs
wrong forum pal hah
Old 06-22-2018, 09:27 PM   #64
bryan.catano93
Drives: 2013 frs
https://datazap.me/u/bryancatano93/l...6?log=0&data=7
heres a wot log. car is still overboosting a lot. not hitting fuel cut but im still scared of those numbers. specially with the low rate springs. imma put a softer spring today and check at what psi it opens.
take a look
Old 06-22-2018, 09:30 PM   #65
bryan.catano93
Drives: 2013 frs
What are your MAP readings when the engine isn't running and at idle? Incorrect settings may well idle if they aren't off by too much at the lower end of the scale, which I can't imagine they are between a 3 Bar and 4 Bar if we're talking Omni sensors. The doc I have to hand puts the offsets very close (0.03/0.031). However, if I have this right, the tune for the 3 Bar map would give lower readings if running a 4 Bar sensor. You would need to be running a 3 Bar sensor on a 4 Bar map to give high readings. Either this is your problem (or the multiplier has been input wrong by accident to cause the same issue) or you're overboosting. The latter should really be ruled out by changing to a lower pressure spring, which you've done.
I assume no analogue gauge to compare it to?
thats with the engine idling. and i think ifs 1bar when car is off
Sudden Power Loss / Hesitation and jerking under WOT Jesse36m3 Forced Induction 6 05-14-2018 09:59 PM
Engine bogging / stumble / hesitation / jerking during accelaration ard 2.5k - 3k RPM mo420 Issues | Warranty | Recalls / TSB 24 07-29-2017 07:35 PM
CEL p0456 code, jerking when braking RedNWhite Issues | Warranty | Recalls / TSB 7 06-03-2016 06:35 PM
M/T and idling over speed bumps - jerking mstoochn Issues | Warranty | Recalls / TSB 7 04-29-2015 04:45 PM
Was I being hard on my car? Fr-s13 Scion FR-S / Toyota 86 GT86 General Forum 49 07-04-2013 09:54 PM
