Old 04-28-2015, 09:10 PM   #1
mstoochn
Drives: 2015 WR Blue Sport Tech BRZ
M/T and idling over speed bumps - jerking
2015 Brz sport-tech m/t, this is my first m/t car so perhaps I'm just clueless.
Whenever I go over a speed bump at low speed in gear (8-15kmph) the car will be in gear and I let it creep over the speed bump, as the car goes over the speed bump the vehicle will begin to rock (in the same manner it would if you drop the clutch at low revs) but 1st gear is engaged and my foot isn't on the clutch - is this a characteristic of the car or should I be doing something different?
mstoochn is offline   Reply With Quote
Old 04-28-2015, 09:26 PM   #2
You are letting the revs drop to far and it is lugging. If taking a bump that slow clutch in just before rolling over and clutch out and accelerate like normal after you g over. Never let the revs to so low that you start to shudder, "rock" or in any other way lug the engine.
Old 04-28-2015, 09:40 PM   #3
chas3wba0
chas3wba0's Avatar
Drives: Yes
Practice more n00b
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 04-28-2015, 09:55 PM   #4
mstoochn
Originally Posted by chas3wba0 View Post
Practice more n00b
lol thanks, figured it was just me being a noob.
Old 04-28-2015, 10:23 PM   #5
extrashaky
Drives: 2014 BRZ Limited
It's not like an automatic where you can just use the brake at low speed and let the engine and transmission do the work for you. At low speed you have to work the clutch, give it some gas if necessary, coast if necessary. You don't want to lug the engine because the oil pressure will drop too low and not lubricate properly, resulting in premature wear. If you have to go so slow that your RPMs drop low enough that you're lugging, clutch in and coast instead, giving it a bump as necessary to keep yourself moving.
Old 04-28-2015, 10:38 PM   #6
Xuningshen
Drives: Subaru BRZ
it takes effort to go over a bump right? how much power does the car have at idle? of course it'll bog down for a second.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 04-28-2015, 10:45 PM   #7
chas3wba0
chas3wba0's Avatar
Drives: Yes
Yea depending on the size of the bump, you'll probably have to ride the clutch and give it a little throttle to go over smoothly. It's fun once you get the hang of it
Old 04-29-2015, 04:45 PM   #8
stevesnj
stevesnj's Avatar
2nd gear with some throttle you should be good.
My 2016 Build thread
New manual driver - SPEED BUMPS! eifer Engine, Exhaust, Transmission 47 06-16-2015 01:27 PM
speed bumps jmaryt Scion FR-S / Toyota 86 GT86 General Forum 25 03-05-2014 10:34 AM
6 speed m/t idling low Gt86_nick Engine, Exhaust, Transmission 1 01-28-2014 07:54 PM
Coilovers & speed bumps autoCAR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-12-2013 12:36 AM
speed bumps jmaryt BRZ First-Gen (2012+) — General Topics 15 01-20-2013 02:48 AM
